Andyinchville1
Hi
The other day I was thinking a drain plug was leaking fluid because a drip was forming on the bolt head ....
I had no idea what the drain plug was for because it was not the engine oil drain plug nor was it the transmission oil drain plug.
Turned out it was just a bolt with oil that was about to drop off of it.
Looking under the car and following the trail of dirty dried up oil it turns out that the oil leakage is around vacuum pump area.
I tried to take a paper towel to the area to see exactly where the leak is coming from but I suspect it must be coming from a gasket mounting the vacuum pump to the valve cover area.
I had inquired in the past as to how often the vacuum pump should be replaced and it seems to be one of those lifetime Parts almost like hoses until they go bad.
Anyways I'm thinking I need to replace at least the gasket causing the leak and I'm almost halfway inclined to just replacing the vacuum pump just because it has four hundred forty thousand miles while everything is apart.
What is involved with removing the vacuum pump and I'm guessing there's a gasket that needs to be replaced?
Anybody have the torque specs for the bolts or just basically tight until snug?
Thanks in advance for any and all help.
Andrew
Andrew
