wow, you really stepped up.my old commuter car...94 corolla
I've had the warning lite up 4 times already. Only 1 was actually a low tire that I had to have fixed. The other 3 were all false warnings.I've already had one false "low tire" reading, when all were exactly the same PSI.
What PSI do you set to?I've had the warning lite up 4 times already. Only 1 was actually a low tire that I had to have fixed. The other 3 were all false warnings.To say I don't trust the light is an understatement.
Might want to fill your tires with nitrogen, it is much drier than compressed air, the dampness can affect the sensors. You get a more consistant tire pressure over temperature change as well.
I'm with Bill on this one, I've even had a Michelin engineer tell me it's all crap and just a way to get an ext buck out of consumers.......regular air is what 80% anyways.A new 'benefit' to running N in tires.:roll eyes:
Good old dry 'AIR' will do just fine.
Bill
Honestly they are set by either my tire dealer or the dealership. They are setting it to the door sticker.What PSI do you set to?
Huh? That's the first time I've heard that one.We picked ours up - 7.6 total miles - and were told to drive it around a bit and then bring it back for them to adjust the tire pressure.
We're also going to have it washed . . .)
Most of the tire stores around here have jumped on the NITROGEN IS HOLY bandwagon. They want to UPCHARGE you for it. If you tell them no thanks, plain old air is good enough.... THEY WILL PUT THE NITROGEN ANYWAY because it is all they have.Do either of you know what dry air is and do you think you get it at the gas station or a tire store? Filled up new triple treds 3 years ago with 98% N2, never added, 30K miles, and still at 32 psi when I checked a couple weeks ago. You guys keep checking your "Good Old" tires and remember this when your sensors fail or misread.
First off, you have my most sincere apologies. Allow me to explain.The topic was trouble with the sensor system, which you rolled you eyes at my comments. That was your welcome to the club, too late now.
<SNIP>
Did you see the memo? I'll go ahead and make sure you get another copy of that memo.Just pick up and tps light came on. Anyone know how to reset?
