BeetleDragon737
Hi all. I have a 1999.0 New Beetle. I'm having some troubles with my TPS or electrical connections related to it. I know this is a common problem, but it seems to be one that is very difficult to diagnose.
From what I've read, the issue could stem from a bad ECU, a bad TPS/pedal, or any one of a number of bad electrical connections. I've taken my car to a knowledgeable shop, and they spent a while checking out the voltages and resistances related to the TPS and such, and they said everything looked good. The only issue was some serious corrosion around the grounds at the ECU, which they cleaned. I drove the car for another 40 miles, and then the accelerator died again.
I'm on the verge of replacing my TPS and/or my ECU, but I don't want to spend $1200+ when that won't necessarily fix my problem. I also would like to get a tune, but I don't want to tune my ECU if it's what is causing the problem.
A few questions:
A few questions:
After you all have heard about this issue again and again, what seems to be the most reliable way the problem gets fixed?
Are there any differences between an ECU issue and a TPS issue that I would be able to notice as I'm driving and the pedal gives out?
And are there any electrical connections that are easily accessible that I could visually inspect for corrosion, etc, that wouldn't require electrical engineering expertise to fix up?
