Clearcoat is peeling in some places, mostly on the hood. Not my first pick for the colour but its growing on me. We call it the Yellow B
It has a Mazda "R" trans used in the B2600i, Turbo RX7, and the MPV. There is a smaller "M" trans used in the N/A RX7, B2000/2200, and Miata. The "R" is quite beefy and there are a lot of high HP RX7s out there. Good trans pics
here
There are also crosses between the diffs as well, the "R" trans cars/trucks got a 8" rear that's mostly interchangeable and the "M" trans cars have a 7" diff that's also used in the front of the 4x4 trucks. A few options for pozi and LSDs from the RX7 community, barely any aftermarket parts for the B compared to a Toyota.
I already cut the tunnel out to convert my truck from a auto to a manual plus I "should" have enough firewall clearance for the vacuum pump and a auto coolant flange.
There aren't any adapter options for the Mazda that's why I was looking into Toyotas. Plus the fact that I can get a 2000+ that has all the extras. Although, I'm leaning toward getting a machinist I know make me an adapter plate I just have to find a RX7 transmission on the cheap. The transfer case just replaces the tail housing and the bellhousing is even removable, I would be going with a RX7 bell anyway because the starter position faces towards the trans like the 02J. I cant find Diffs to drop my highway RPM but if I use a RX7 trans and bump up my tire size to a 30x9.5R15 my RPM will be exactly the same as the Jetta.
The only thing I'm really concerned about is the cranking power on the RX7 starter. I don't know but I would imagine a rotary would require much less starting torque than our TDIs?
I've been researching and reading and searching some more on TDI swaps for 4 years or more. I would LOVE to get my hands on a 5 or 6 cyl TDI, I think that would be a better option for a small truck instead of highly modifying a smaller one. But you use what you can get your grabbies on and the ALH/BEW engines are everywhere, not to mention how awesome they are!
Enough blabbering from me! TMI?
Mike
