jimbote
Certified Volkswagen Nut
Tach output discovery!!!
OK...when I first built my harness to do the ALH floor start I identified the wire I suspected of being a tach output wire.... green/brown @pin 27 of 121...my ecm is of Y2K vintage ...well I checked AC output voltage at that wire with my meter it was reading 7.2VAC...so I took a leap of faith (or stupidity) and brushed it against the tach input to the cluster while the truck was running....the needle jumped...so I twisted the two wires together and blipped the throttle....it worked!!!
...I have tach now by just connecting the green/brown pin 27 from the ECM to the black tach input to the toy cluster....appears ALL 121pin ecm's have this wire, same color same pin location.....also hooked up my boost and egt gauges as well as oil pressure light (idiot
) and the temp gauge using the Toy temp sending unit ...EDIT!!...actually SDturbo is the one who gave me the idea for this in his Volvo wagon swap but iirc he was using a 1Z/AHU so a different ECM that does not use canbus for the tach....thanks SD!!
