TurboABA
- Joined
- Jul 24, 2010
- Location
- Kitchener, ON
- TDI
- RIP-2010 Jetta 6spd 2014 Touareg Execline '14 A6 Technik S-line
One more monitor to clear... Almost there
Does that just mean "More miles driven" (hopefully)? I've never had any fuel issues that I know of.One more monitor to clear... Almost there
If you want to get technical, this is what's left:Does that just mean "More miles driven" (hopefully)? I've never had any fuel issues that I know of.
Friday,07,February,2025,12:41:27:17938
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVGFK9BP2CD002618 License Plate:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
69 6D 72
VIN: WVGFK9BP2CD002618 Mileage: 196970km-122391miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H17 0008
Revision: 56H17--- CVN: 66FD960038D3FF8238D3FF82
Coding: 292A4012233600050000
Shop #: WSC 06434 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 36352E9D58C31C9AB57-8062
VINID: 9E65D66C94A009350000218120AEFB2227
No fault code found.
Readiness: 0 0 0 1 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-7XX-V1.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 3407
Serial number: CVN: CB5A7D50
Coding: 001368
Shop #: WSC 40652 001 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 30391885BAA732AAEFB-8064
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 419910010EC010 Dataset Number: 7P0012v____ 7P13
Coding: 5B7613C349242555DAFAC89492DAA4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 45D75951152587022CD-8010
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 09860000000000000000
VCID: 73B3D7890BB149B2529-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Serial number: 0811000103305003
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000151030014
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: B606200880
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 74B1D4950E3F4E8A4B3-8020
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001007544
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 6B83CFE9538191729A9-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110708 31 0020
Serial number: 90243400110726233859
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10212139
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000001208110308
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0L6D06
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28291120696381
Coding: 110001
Shop #: WSC 19419 444 123965
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 42DD424D040BB03A09F-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag025 H05 0023
Revision: -------- Serial number: 003JX003M0D7 Dataset Number: 7P6003v____ 0785
Coding: 000000000000000000000000000000003235
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 40D948450A07A22A1FB-8014
Seat occupied recognition:
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1142704U3G
Crash sensor for side airbag: driver side:
Serial number: 3575LRB405P0NLV24G4%
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404R0NLV240TA
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515RRB405T0LCOQEPUB
Passenger side rear thorax airbag crash sensor:
Serial number: 3525RRB40650LCOQGPCG
Crash sensor for front airbag: driver side:
Serial number: 3555NRB40630I3GU7GS
Crash sensor for front airbag: front passenger side:
Serial number: 3565NRB40630I3GU6G5F
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KHB00035
Coding: 000015
VCID: 36352E9D58431C9AB57-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0100568
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658150811593034
Coding: 8B6733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526_VW52.rod
VCID: 47CB53592F299512DE1-8012
1 Fault Found:
9453074 - Fuel Level Sensor 1
B103E 1B [00001000] - Resistance Too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 58
Mileage: 196925 km
Date: 2025.02.02
Time: 18:50:44
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000212820
Coding: 0001037500
GVL: FB4F40051D7B000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 382920A552D7EAEAA7B-806C
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650222545
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000118433346
Coding: 011D07200000453005080000
VCID: 44D144551E9FBE0A3B3-8010
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0155534842
Coding: 0186123A28B9500080A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 188112346
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000118706868
VCID: 3B233FA96361C1F24A9-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11725003DC Dataset Number: A001
Coding: 01040200
ASAM Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0008
Coding: 010A00010F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1FCB5266F06CA033-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H52 0076
Revision: AB001007 Serial number: 156HX0B7541045
Coding: 020007020100000001
VCID: 1F1BEB39D7B9BDD2461-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445H00B7518681
Coding: 010200050040E1ED01022B0E00000003F0000101
VCID: 372B23995F49E592AE1-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H25 0045
Serial number: VWZ8Z9L79002J4
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000118761720
Coding: 011C07200000253005080000
VCID: 3A2D3AAD6C5BF8FA51F-806E
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000039276 Dataset Number: 7P6096v____ 0016
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB4BB977F9DDD2661-806A
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000155067882
Coding: 020D000000000000
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 211100085 Dataset Number: 7p0771v____ 0009
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000118758747
End----------(Elapsed Time: 01:54, VBatt start/end: 12.2V/12.2V)-----------
Did you perform the specific drive cycle required to complete readiness?Not yet. I've driven it to work all this week without any death countdown or check engine lights.
No, I haven't had the opportunity. Just my normal drive to work which is only 19 miles of open highway and the rest is in normal traffic.Did you perform the specific drive cycle required to complete readiness?
And yet, you're expecting results.....No, I haven't had the opportunity. Just my normal drive to work which is only 19 miles of open highway and the rest is in normal traffic.
Readiness is still showing the fuel system issue
No, I only scanned it today so I could respond to your post. I appreciate you asking. The next time I have an opportunity to go a full 30 minutes on the highway, I'll make an effort to satisfy the criteria and see what happens.And yet, you're expecting results.....
Key on, engine off.
[Select]
[01-Engine]
[Basic Settings - 04]
IDE04567 Resetting of SCR tank level detection
[Go!]
Should get message of "Finished Correctly"
[Stop]
IDE04730 Reset SCR lock
[Go!]
[Stop]
[Done, Go Back]
This is something else, which you did not mention until now.I do still get the service now icon when I start up
You did not erase the codes first as directed.
Go into engine controller and erase codes.
This is explained in your owner's manual.As for the service Icon the wrench that pops up when starting then goes away I though was only due to regular service intervals in which I have completed
