CoriolisSTORM
Gents, I did my timing belt a few weeks back, and checked my torsion value. It is "0". I have a hard time imagining that I actually got it directly on 0. My understanding is that a value outside of its range will show as 0. How can I determine mine is in the correct spot? I bought and used all the proper tools and locks/pins from KermaTDI, as well as the proper kit. Is it something to be worried about? The car as far as I can tell is running fine. Thank you all for your help! I will try to do the DSG service, air filter and oil change next weekend, so if I need to tear back into it, that'd be the time to do so.
edit: Took a quick run around the block to get the engine back to optimum temp, yep, 0.0, and specified injection start is 1.9 BTDC. Does that help any?
