An air hammer might, but a pneumatic impact gun will not.Using an air hammer will ruin the wheel bearing.
No, it will not ruin the wheel bearing. The axle nut pins the inner race between the outer CV joint and the axle nut. Squeezing the inner race will not damage anything. If this method ruins wheel bearings, my cars and all others I have worked on remain unaware of it.Using an air hammer will ruin the wheel bearing.
Hmm... that's interesting. Apparently, the manual on CD differs from the printed manual. I have the printed manual, and it says this:from the bently cd.
Tightening torque:
Note that when you turn the wheel, it's with the wheel installed on the car, and the car on the ground. So you're rolling the car forward or back, to make the wheel rotate 180 degrees.Tightening Torques
12-point nut for drive axle to wheel hub
-- 200 Nm (148 ft-lb)
-- loosen 1/2 turn (180*)
-- turn wheel 1/2 turn (180*)
-- then tighten to 50 Nm (37 ft-lb) plus 1/6 turn (60*)
Hex bolt for drive axle to wheel hub
-- 250 Nm (184 ft-lb) plus 1/4 turn (90*)
-- then tighten to 250 Nm (184 ft-lb) plus 1/4 turn (90*)
I say that every time I go to bed.could have been a life threatening disaster and we got lucky.
bolt is m16x1.5 nut is m20x1.5(this would explain the difference in torque specs).
The main purpose of the axle torque spec is to get the required amount of clamping force on the wheel bearing. Regardless of what type of fastener is used, the bearing still needs that clamping force to hold it together. The nut with lubricant has a lower torque spec, because less torque is needed to achieve the required clamping force on the wheel bearing. The bolt needs higher torque, because it's installed dry.bolt is m16x1.5 nut is m20x1.5
bolt is stretched every use, nut is not
16x1.5 bolt stretches at say, 26klbs of clamp loadThe main purpose of the axle torque spec is to get the required amount of clamping force on the wheel bearing. Regardless of what type of fastener is used, the bearing still needs that clamping force to hold it together. The nut with lubricant has a lower torque spec, because less torque is needed to achieve the required clamping force on the wheel bearing. The bolt needs higher torque, because it's installed dry.
The fact that one is a big ole nut and the other is a stretch bolt doesn't matter much, as far as the wheel bearing is concerned. They're just two different ways to achieve the same goal. And that goal is X amount of clamping force on the wheel bearing.
I tried the Bentley method and had to replace both bearings 3 weeks later because there was so much play. Both tires were slapping like they were going to fall off. I used an impact wrench to tighten both nuts and 40k miles later, everything is still OK. I used NAPA nuts with the nylon insert. Just my experience. May fail tomorrow but lasted longer than before.
Did you put a new nut on or reuse the old one?I had alot the same experience, i torqued the nut to spec and a week or two later i noticed something wasnt right so i checked the nut and sure enough it was loose and the wheel wobbled back and forth like the bearing was out.
