cpinde
- Joined
- Sep 24, 2012
- Location
- Slower Lower Delaware
- TDI
- 05 VW Passat, 04 Jetta, 06 BRM Jetta, sold 15 Golf current
I'm sorry to beat a dead horse but I just picked this car up 2 months ago and now I see why it was such a good deal. I only have 129k on it and the TC code popped up a couple weeks ago. I'm a MKIII and MKIV guy so I have a OBD Scanner in every car. I scanned it and then cleared it. I haven't had the code come back. Yesterday while doing some spirited driving it went into limp mode and the gear indicator in the gauge cluster went "solid". Still no codes though. Today when the car warmed up I couldn't go above 2k RPMs at more then 50% throttle or else the car would stutter. So I called around to see how much a reman transmission is and need to wait a month or two to make sure I have the money to do the transmission, the BSM, and timing belt at once.
So after the long story I need to know if anyone else has been able to drain the transmission fluid/refill and have the transmission last a while. Or should I just refill it. I'm worried that the fluid might've drained out of the TC and without pulling the trans and TC that it won't get enough fluid back into it to even make a difference. I appreciate any advice I can get.
