Most cars are -0.10 to -0.whatever, its so the car drives strait and does not wonder.
our MK3's are a little toes in. so -0.10 is about right. if your doing the string method (works great) you want no more than -3/32 of an inch of toe in.
Toe is supposed to be at zero. Camber is supposed to be negative, ideally at least a half degree. Max the spec allows for camber is -1.0. I used to set my personal mk3 up at -2.0 camber, toe at zero, and it still wore relatively evenly...
Of course my driving style may have helped ensure the wear was relatively even back then
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
