TDIJettaz
I have the chance to buy an '06 BRM Jetta with 207K. I don't know when the TB was replaced, there is a rubbing noise in the engine somewhere at idle, and brakes may have some issues too. I have pasted the results of my Vag-com scan below. Someone please tell me if the results show any major problems. I scanned the engine, transmission (No faults), brakes, electronics, and instruments (No faults). Also, the idle speed is at 840/min which seems a little bit low to me.
___________________________________
Tuesday, 28, July, 2015,18:22:01:32264
VCDS Version: Release 11.11.3
Address 01: Engine Labels: 038-906-016-BEW.lbl
Control Module Part Number: 03G 906 016 AC HW: 028 101 223 9
Component and/or Version: R4 1,9L EDC G000DG 7551
Software Coding: 0050078
Work Shop Code: WSC 00066 000 00000
VCID: 64CDB249A7409E9
1 Fault Found:
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 2
Mileage: 331314 km
Time Indication: 0
Date: 2000.00.00
Time: 01:31:39
Freeze Frame:
RPM: 2205 /min
Speed: 105.0 km/h
Temperature: 34.2°C
Absolute Pres.: 1193.4 mbar
Mass Flow: 41.24 g/s
(no units): 2.59
Temperature: 84.6°C
Readiness: 0 0 0 0 0
Tuesday, 28, July, 2015,18:37:30:32264
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Control Module Part Number: 1K0 907 379 K
Component and/or Version: ESP FRONT MK60 0104
Software Coding: 0021122
VCID: 3A712C317544B89
3 Faults Found:
00493 - ESP-Sensor Unit (G419)
014 - Defective - Intermittent
00495 - ESP-Sensor Unit (G419); Supply Voltage
012 - Electrical Fault in Circuit - Intermittent
00778 - Steering Angle Sensor (G85)
Tuesday, 28,July,2015,18:27:06:32264
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 1K0 937 049 C HW: 1K0 937 049 C*
Component and/or Version: Bordnetz-SG H34 0803
Software Coding: F4098E02400418000014000000140000002077035C
Work Shop Code: WSC 00000 000 00000
Additional Info: 1K1955119B Wischer VW350 012 0401 1K0955559M
RegenLichtSens 005 0605
VCID: 2F670D65BE066D1
5 Faults Found:
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
01598 - Drive Battery Voltage
000 - - - Intermittent
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
01501 - Bulb for Blinkers; Rear Left (M6)
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 331314 km
Time Indication: 0
Date: 2000.00.00
Time: 01:31:39
Freeze Frame:
RPM: 2205 /min
Speed: 105.0 km/h
Temperature: 34.2°C
(no units): 2.59
Temperature: 84.6°C
3 Faults Found:
5 Faults Found:
