bryanmabbott
I have a 02 Golf with a manual at 232k miles and wanted to give it some TLC/new life. I just finished the timing belt a couple weeks ago if you remember that thread. So anyways, I'm looking to update the suspension and have the clutch installed.
1st Question: Is this a good clutch?
I'm looking for quiet (no clutch chatter) and durability but able to hold the torque when I'm accelerating onto the freeway.
-South Bend Stage 1 clutch kit with 17lb SMF *part #K70316 Rally. In 2009 (~80k miles), my dad upgraded the car with the Kerma 150hp package which included:
-Garret 17/49 VB turbo
-Turbo adapter + hardware/gaskets
-Kerma stainless steel turbo oil supply line
-Fratelli Bosio Power Plus 764 injector nozzles
-3 Bar MAP
-Q loader tuning software, but tuned for the stock clutch as my dad wanted to keep the stock clutch until I learned how to drive a stick in 2010.
2nd Question: Is the clutch install TDI specific?
I know that the flywheel has a stamp to indicate when the crank is at TDC. I want to have the VW/Audi shop that did my timing belt do the job if only it is not TDI specific, the TDI guru in Phoenix is always busy.
3rd Question:Is this a good suspension set up?
I was thinking Bilstein TC comfort with the Audi TT bushings/GTI mounts and ball joints from Boraparts. I do mostly interstate/highway cruising so I'm looking for comfort (but not mushy) for long freeway drives but at least handles corners with spirit, not race car like. I do have 15" wheels and I sometimes load up the car with 4 people and luggage for travel.
Thanks for the help, I know it's a lot of info but I figured it's better to ask than to just install and not like it.
-3 Bar MAP
