Karl Roenick
- Joined
- Sep 22, 1999
- Location
- Clifton Park, NY, US
What tire pressure do you use?
I'm going to use, I think, 40 psi.
Minimize the contact patch between tire and road. Toyota has a car that has prius sized tires on it just so that it wags its tail. I would say fill your rear tires to max pressure and keep your front tires inflated to VW specs probably found in your door jamb and see what may happen - at your own risk of course.How do you create oversteer on a front wheel drive car? The only way I can get the back to come around is to use the hand brake-otherwise the front always pushes-just wondering.
Heel and toe braking helps induce oversteer or pulling on the emergency brake in the turn all of which eat up pads and rotors. That's the way a buddy of mine road raced his 900 Saab back in the early 80s. Effective tricks to combat inhertent "push" in our poor FWD.PassatTDI 38F 37R cold. Goodyear Crap
88 Golf 37F 32R. D60s or A509
RabbitGTI Kumho AX tires 35F 32R
How do you get a FWD car to oversteer? Go into a corner a little too hot. Turn in hard and lift at the same time. Get the timing right and it will rotate. Ya gotta be a little violent so the car knows you mean it! Get ready to catch it and when it is pointed in the right direction, plant it. The best way to get neutral handling on a VW is to add a bigger rear anti-roll bar in addition to the stock rear bar. Take the front bar off and throw it away. Put 38 to 40 lbs in the front tires and 32 or so in the back.
I was just going to say this! What a crazy amount of time to pass and someone actually finding this thread. THIS is why we keep telling people to use the search function. For what it's worth, on my 2000 Beetle I run 42 PSI in the front (they need to be filled every week; leaky seal I think) and 40 PSI in the rear.Epic thread resurrection - almost 15 years!! This could be a new zombie TV series, "The Walking Thread"
and read the thread date............... THIS is why we keep telling people to use the search function. .......
