Humanaquarian
235/45 R18 is stock, is there a tire out there with a larger aspect ratio like a 235/50-55 R18 that would work? Looking for a cushier ride - for a 2014 Beetle.
Yeah I’m running into that. This is the premium trim line, not many made.It might be worth looking at the passat forum as 235/45 18s are much more common on the passat as compared to the bug where it is rare to see anything besides 215/55 17.
The owner's manual and the sticker inside the driver's door have recommended pressures for the 16" and 17" tires
You're the one providing conflicting information...... but anyways, your new sidewall is roughly 1/2" less than what's listed on your sticker, so you'd want a slightly higher pressure in order to stiffen up your tire and reduce potential flex\deformation when hitting a pothole, etc.The sticker only lists the 215/55 R17
