Diesel Viking
Hello all,
I recently purchased a 2012 touareg tdi with the CATA engine. Intake bank 1 reached up to 10 degrees and rattles like crazy on startup. It's definitely time for a new timing chain. I know the best way to remove the engine is to drop it out through the bottom, however, I do not have access to a lift. I would like to just pull the whole front end apart like I did with my MK5 jetta tdi and pull it straight out through the front with my cherry picker. I'm hoping to get some advise or tips from anyone that has replaced the timing chains or pulled the engine on one of these cars. If anyone has any suggestions on what seals I should replace while it is out I would greatly appreciate the information! Would be happy to take some pictures and do a writeup after if one is requested.
Thanks for reading!
Thanks for reading!
