ukguy
Hi all,
I was recently doing a cam timing adjustment on my engine which is a 1.9 diesel in a Golf MK5, engine code BKC. I thought I would check the tensioner as the head was recently removed. Can someone please just check the pointer in the attached picture, I believe it should be lined up with the cut away notch on the back plate.
http://www.zoo.co.uk/%7Eadam/tensioner.jpg
As you can see, the pointer is actually slightly to the side. Should I be concerned by this and get it changed, or is it nothing to worry about and there is 'some' flex in the belt because of the extra tension?
Thanks!
Thanks!
