Timing belt on a budget
TDI_Dan
Michigan
2015 GSW 6M MKVII, 2011 Golf TDI 6M (bought back)
Yes, delayed expense. Doing it twice and paying for damage when it fails prematurely.
Cheap and Volkswagen don't make good bedfellows.
I assume this is on your '98 Beetle? There really isn't much shortcutting to be done here. If you are mechanically inclined, can follow directions, and purchase the necessary tools, you can do it yourself and all you'll need is the parts.
You'll find the parts kit prices won't vary much, maybe $30 or so from the least to most expensive, so long as you are comparing equal, quality, complete kits. If you find something much cheaper, it will be incomplete, Chinese junk, or both.
SkyRyder55
Winnipeg, Manitoba, Canada
1998 Jetta TDI, 1990 Corrado G60 (AHU soon)
timing belt and budget should never be used in same sentence. As above stated, do the job your self or take it to a shop. but cheaping out will cost you potentially thousands short or long term. not worth it. some things you can skimp on. the timing belt is not one of them.
scurvy
Good Ol' Boy
Chicago IL USA
2006 Golf
Cheapest place is Rothenbacher Engineering [SIC] or Prothe.
For parts that will fail and destroy the engine in short order, yes. :mad:
Rent the proper tools and buy a complete kit from one of the well-known quality vendors. Don't shortcut the job or mark & pray it. It's not hard to DIY correctly.
454k30
Long Beach, CA
2002 Jetta
Everybody is saying it, but I'll jump on the wagon anyway. The cheapest way is to buy genuine replacement parts from a place like IDParts or Dieselgeek. While you are there buy the proper tools as well. Oh, you will also need VCDS to get everything working properly after the mechanical work is done. Don't cut corners on this, replace what needs to be replaced.
BleachedBora
Gresham, Oregon
'81 Caddy CJAA 250 hp/450 tq, '05 E320 CDI, '81 DMC-12, '18 GLS63 AMG, '98 Land Rover Defender RHD TDI, '74 Rotary Beetle
Mark and pray = park and pay...
Whitecloud1
Wisconsin
02 Mk4 w/ 250K+ . 2013 Passat SEL 45K+
Buy the parts at a quality shop as mentioned above and get a TDI'er to do it at one of the GTGs. Plan on a 4-5hr job and make sure you pay him well....if he knows what he's doing.
As others mentioned, if it's not done right, it reeeeally gets expensive when your motor gets trashed.
