Garrett0153
Hey y’all. I have okay experience with cars but I’m still pretty new, and this is my first TDI. I have a 2013 VW Passat TDI SE at around 120,000 miles and about 2 months ago I got into a small fender bender that bent my radiator a little bit. Bit after my water pump started leaking a little, and then a lot. I don’t think the radiator being bent had to do with my water pump leaking. Anyways, I just got my hands on the funds to replace the timing belt, water pump, etc. and got it all done besides the radiator. Nothing is leaking anymore but now she ain’t starting. Was running perfectly before this work. I don’t have VCDS but was able to pull two codes, P020B cylinder injection timing, and P020D cylinder injection timing. I’m stumped because I am pretty confident that everything is in time. I mean, maybe not? Although, I do not own the crankshaft lock. I do get flashing glow plug light only after trying to start it. I have been able to start the car 3 times after the replacement and was able to drive it two of the times. Nothing sounds like it’s knocking, and once the car starts it drives and sounds perfectly fine, other than a slight roughness on acceleration in neutral between 800-1000 rpm. There should be no air in the fuel lines as I have started it and did not remove or play with the fuel lines. The only thing I have noticed is that the fuel timing is ranging between -4 to 15 when started. I have no idea if that is normal or not. Hopefully someone has an idea because I’m stumped.
