Timing belt, DSG service and delete at the same time?
kg4geq
Ozark, Missouri
2014 Jetta Sportwagen
I have a 2014 mk6 cjaa tdi sportwagen about to hit 120k miles. It will be due for 120k DSG service (with fuel filter replacement) this oil change. I also have timing belt/water pump kit to install. Lastly. I have Eco dpf delete and tune (dsg also) kit to do.
I’ve done the dsg service myself twice at 40k and 80k and am familiar with it. I’ve got the instruction guide from here for the timing belt service and kit from ID parts w/metalnerd tools. Sounds like it may take about 6 hours.
I don’t know how long it will take to remove sensors and delete tune. I have shop with a lift at my house.
Would you do all these projects at the same time over a weekend? Or 3 separate, independent service jobs? I have other vehicles I can drive if it take longer. My thought was it maybe beneficial to knock it all out at same time? But worried if something goes wrong with delete tune or timing it may be hard to diagnose which is which.
Appreciate you experts’ thoughts. Thanks!
AverageAndy
Phoenix, AZ
2013 Passat TDI SEL, 2013 Golf TDI 6MT, 2013 Jetta TDI 6MT (R.I.P.)
Not an expert by any means, but I would do the DSG service and timing belt/water pump together, then drive it a little to make sure everything is working ok. Then tackle the ECO kit as a second, fun project.
Tuheeden
North Carolina
2013 & 2014 Jetta sportwagon
To be honest, the timing belt, delete are on the other side of the engine so I would do the transmission fluid change separately. The delete is a solid 4-6 hours and the timing belt is likely 2 hours. You can get it done in one full day without too much trouble.
turbobrick240
maine
I say try to knock it all out in a day. Then you have bragging rights if successful.
