Hi everyone. I have a 2013 TDI with 75k. Recently the timing belt snapped which seemed odd at that mileage. After taking everything apart the water pumped had seized and snapped a part of the pulley off. I put a new pump and belt on it and tried to start it and it ran for a few seconds and then shut off. So I figured some valves were bent. I recently just pulled the engine and took the head off to notice that all the valves are fine and found 4 rocker arms snapped in half. I read that there was some kind of lawsuit over the water pump issue they have. Does anyone have a set or at least 4 rocker arms and maybe lifters they can part with? I have 1 lifter I pulled that separated from its base. Thanks everyone.
