Timing Belt Blues
Turbo Girl
Bloomington
2006 Jetta TDI/5 speed
So I have heard some conflicting information regarding my timing belt and I am hoping that someone can help set me straight as well as give me some pointers on the most cost effective way to get it replaced.
I drive a 2006 VW Jetta TDI 1.9L. It roughly has 120,000 miles on it. I was under the impression that once the vehicle reaches 100,000 I NEED to replace my timing belt. My friend who is a mechanic and seems to have a lot of experience with VWs told me that it needed to be done (my friend is kind of a scammer so I am not sure if I entirely trust him to work on my car).
However, I have been asking around and many people have told me that I can wait until it reached 150,000 miles before it is completely necessary and I've also been told that I can wait until my car reaches 200,000. I am planning a trip in June that will require about 2,000 miles worth of driving.
Please help!?
04SlvrJetta
Wheeling, WV
15 Passat SE DSG
Oh, and pointers...if you're not doing it yourself then you need a trusted mechanic. Only quality parts should be used and can be obtained through vendors such as IDParts.com. The good vendors that support TDICLUB offer all of the parts as a kit.
Lightflyer1
Round Rock, Texas
2015 Beetle tdi dsg
IIRC the requirement was reduced to 80k miles. You are already on borrowed time here. If it breaks you will do damage to the engine itself. Please check the trusted mechanics thread and get this done as soon as possible. It may last or it may break tomorrow. Do you want to take that chance with ruining your car?
http://forums.tdiclub.com/showthread.php?t=130044
Please get one of these mechanics to do it correctly. Don't let your scammer friend do it. It requires a kit and some special tools and the knowledge of how to do it right. Spend some time on here reading about others who have had this issue. Some self education here is in order so you aren't taken advantage of.
Jeepaholic
Fenton, MI
1999 Golf, two door. Manual trans, manual everything else.
Yes, don't push it. You've made it to 120K, be thankful. When the belt brakes it'll cost you substantially more than if you do it now. The cost of a broken belt will easily stretch into 4-digits.
cleaver
Berwick, Nova Scotia
None - did own '01 and '02 Jetta TDI
Boom.....$4000 later.....
Jason - you are always so eloquent...but are 100% correct.
As the above persons have said, you are far past the scheduled maintenance to replace your timing belt and all parts along the belts path.
Find a good mechanic that has the necessary lockdown tools and use quality parts. If you don't find a guru near you, ask some more questions here - definitely don't let the dealer or just any mechanic do the work.
Doing the job wrong or with inferior parts is just as bad as not doing the job in the first place.
WalrusBurger
Athens, GA
2000 Jetta (5-speed)
Go ahead and get it changed. I just got mine changed (although it was due to a leaky water pump). The mechanic doing it has another engine in his shop that's he's repairing to the tune of about $3000 because the timing belt broke.
Turbo Girl
Bloomington
Thanks everyone! I am going to get this done ASAP! I am pretty new to this forum and I really appreciate your input. It is nice to be around so many knowledgeable people! :)
Ol'Rattler
PNA
2006 BRM Jetta
Please help!?
Be really careful about maintenance by consensus. Because you are female, a lot of male folks will puff up a bit and offer you advice that doesn't have much basis in reality.
There is a maintenance schedule in your owners manual that should be treated as fact.
for a 2006 BRM, the original recommendation for changing the T/B is 100K miles which VW later changed to 80K miles.
jasonTDI
TDI GURU Vendor , w/Business number
Oregon, WI
04', 05', 06' TDI's. Audi SQ5, RAM Rebel
Or just drive up and I can do it in under 3 hours.
Turbo Girl
Bloomington
Great guys! I am on this...JasonTDI, where in WI are you? My family is from northern IL so another hour drive would not be that big of a deal!
montyypythonss
illinois
2002 jetta
There is a shop in Lawrencville il called lazy 8, he does all the work on my friends tdi, you could check with him 618-392-5222 make sure whoever you use replaces everything in the kit, look and see what comes with them. rollers can fail before belts. ask many questions, if you don't feel comfortable with his answers, find a guru like jasontdi or oilhhammer, i have used oilhammer before, plenty to do in st louis while you wait. the city museum is awesome.
