bbridgerb
- Joined
- Nov 10, 2002
- Location
- Raleigh, NC USA
Timing Belt alligment (GoFaster\'s Replacement Method)
Hello everyone, I have replaced the timing belt and water pump on my 1996 VW Passat using GoFaster's mark and pray method. I marked the belt, cam sprocket, pump sprocket, and crank sprocket with a marker and transferred the marks to the new belt. All went well and I think the car is ready to be cranked but before I do that I want to be 100% sure that everything is aligned correctly. I rotated the engine clockwise using a range at the crank sprocket for at least two full revolutions and didn’t hear any noises. Would it be loud if the valves were hitting pistons? What should I listen for? Is there another way (using TDC) to make an easy check that everything is aligned right? Just curious - What would happen if crankshaft and camshaft were aligned correctly but the injection pump was off by quite a bit? Thanks.
