ukguy
Hi all,
I have found out through the use of Vag-Com that my injection timing is out on my Golf mk4(A4). I have read the guide that relates to adjusting the injection timing but just need to clear up the following please.
When I loosen the 3 bolts holding the injection pump sprocket, how do I exactly rotate the injection pump? Do I just take a wrench to the central nut and adjust this
Or would doing this cause other problems. I have never got involved in the timing belt before, but don't want to take it to the place where I had the timing belt done as they don't have diagnostic equipment!
Any help would be appreciated before I attempt this.
Thanks,
Adam
Thanks,
Adam
