You might not be reading the torsion value, sounds like your looking at the Injection Start box.
Meas Blocks-08
Group 4
Furthest right box marked Torsion Value
Measures in .5°KW increments
Check this out http://www.myturbodiesel.com/1000q/multi/PD-adjust-Idle-TDI.htm
5.4 seems pretty advanced. After i did my cam and timing belt I was at -2.5 and set it to +1.0. Runs really good there so far. As franko6 has shared, there is some trial and error necessary, as every car seems to like a different value. So, maybe start closer to zero and see how it runs and mpgs, then if not satisfied move .5, and repeat until happy?
Retarding the cam to -2.5 will yield better economy but performance will lack. Advancing the cam to 2.5 will yield better performance but economy will suffer.
well it took a few tries but it sitting at 1.0 now. runs about like I remember. wish I had checked the right value before I did it.
oh well.
btw it goes to 7.4 if you go the wrong way and at 0 it won't stay running.
Thanks for steering me in the right direction.
I misunderstood the adjustments. thought the vag com could tweek it, I see now it was just to read it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
