Time for e brake cables
PD Rig
Pennsylvania
2004, 2015 Golf TDI
Hey gents,
Passenger parking brake cable on the mushroom (2004 bew golf) has started to hang up. Any preference of gemo over febi or febi over gemo for cable replacement. I think both are used as or suppliers. I like to keep her as German and original as possible. Also wanted to see if someone can confirm if correct size on the mk4 golf is the 1698mm cables.
JB05
Il.USA
Golf,2005,anthracite blue
I replaced mine with the robust cables from idparts. They are thicker and supposedly won't rust out as fast.
jmodge
Greenville, MI
There is a 1691mm also. You don't want to mix them together. The 1698's will work fine.
jmodge
Greenville, MI
Did the thicker ones fit in the tubes ok?
csstevej
north nj
Yes that end fits fine, you would need the larger clamps and massage the hook to hold the thicker cable sheathing that hangs out the bottom of the rear beam.
Zak99b5
Albany NY
2003 Jetta TDI
We just used zip ties on my sons golf along the trailing arm of the rear axle since we didn’t have the bigger clips handy.
jmodge
Greenville, MI
I did the same with a rubber hose guarding the sheathing at the axle beam
Fahrvegnugen
Burlington Vt
01 golf 1.9 alh gls silver
I zip tied them also. Even with the bigger clips the sheathing tends to pop out of its grip and rub the inside of wheel.
Nothing like wanting to keep your Brazilian Golf with its Polish engine and Argentine (manual) or Japanese (automatic) transmission as "German" as possible, LOL....
Sorry, got a chuckle out of that. Those Brazilians screwed my 2000 Golf together pretty well, must have, it is still rolling along at 603k miles.
All of the A4 platform FWD cars save for the TT use the same cables from middle-2000-on. And I upgrade the earlier ones when the time comes (most already have been by now).
snakeye
Montreal, Canada
2003 Jetta and Wagon, GLS 5sp
The "upgraded" cable is literally the regular cable with some extra tubing slid over it for extra protection at double the cost. The tube isn't sealed on both ends, and due to the cable end being pointed upwards on the mk4 Golf/Jetta, that's just an extra place for water to get in sit, freeze and expand and damage the actual cable. Hardly an upgrade. If I knew this I wouldn't have bought them in the first place. We'll see how long they last on my car...
I agree. I made a thread over a decade ago on the upgraded cables, and I don't bother with them anymore because they are not *that* much better and are still quite pricey, especially considering you need to also replace the hardware to make them secured right.
jmodge
Greenville, MI
Good to hear all this, thanks for the updates, Oilhammer and Snakeye. I'm just about ready to order some parking brake cables. I read where someone soaked theirs in fluid film before installing. I suppose it wouldn't hurt as long as it doesn't make it to the brakes. I don't know if it would make a difference as far as water/freeze/expansion damage goes. But I guess I will stick to standards due to hardware compatibility.
JB05
Il.USA
Unlocking the retainer clips can be rather difficult; it was for me.
Rrusse11
PA Deutsch Country
2002 Golf, 5spd; 05 Jeep CRD
The stars must be aligning, my e-brake is getting a little high on the lever. Said something this morning to my guru while he
did a PA safety inspection; "Have we done the cables yet?".
Nope.
Aaaah, now the question is whether or not to mess with larger clips, or just stick with OEM size and figger that after 200k and
20yrs, the original size will do just fine for the next 20yrs.
wonneber
Monroe, NY, USA
I dd the HD cables from ID Parts on my 03 JSW.
Was the best and easiest upgrade I did. :)
I think I had to bend the cables a bit but it worked great.
PakProtector
AnnArbor, MI
Mk.4's and the Cummins
Too bad we can't get the Goretex ones like the bicycles have. Slick as greased teflon... :) I have a pair of the fat ones ready. The '04 is for sure original, and the '02 likely, and the '00 near certainly.
Douglas
P2B
Toronto & Muskoka, Canada
They fail in the same manner (water intrusion induced corrosion at the low point) as the standard cables. They didn't last near as long as the originals on my car.
Zak99b5
Albany NY
2003 Jetta TDI
Maybe a boot on the end filled with Marine or white grease would help keep out (most of the) water?
And before installing hang them up and fill with 3 in1 oil?
PD Rig
Pennsylvania
2004, 2015 Golf TDI
Okay. Passenger side rubber snapped off in tube. I pulled the tube out so I can drill out the rubber. Now can’t seem to get the tube back into the hole up under e brake handle. Off to thanksgiving dinners. Any tips to get the tube back in? Tried fishing a weed wackier string down in, but it doesn’t seem to be doing the trick.
Any pics of what it looks like under the muffler heat shield so I know what I’m aiming for. Looks like I can see the start of a plastic tunnel but not quite sure.
jimbote
Tacoma 4x4 converted to TDI
It is just a rubber grommet. Aim for that and push it forward. Not sure if this has been covered but you can open up the rear stainless clips to accommodate the larger diameter housing.
PD Rig
Pennsylvania
2004, 2015 Golf TDI
There looks like there is a plastic cross cut tube up there. Is the rubber grommet at the end of it? Do I just line it up with that and push hard? Heat shield is in the way so flying in the dark.
jimbote
Only about 6-8" in. Put a flashlight in the cabin facing rearward to give you light source to aim at.
PD Rig
Pennsylvania
2004, 2015 Golf TDI
Got it in and done tonight. Used the flashlight like you suggested. I used some suspension seal grease on the end of the tube. Slipped right in. Thanks for your help.
sisyphus
Appleton, Maine
99.5, '01 A4 Jetta sedans, 5 sp box, Hamman mod, Joey mod, Bilsteins, 2.00" lift
Make sure it’s the cable and not the screw mechanism in the caliper. Reman calipers are garbage for this.
PD Rig
Pennsylvania
2004, 2015 Golf TDI
It was definitely the cable. Had a ding in the bottom of the passenger side cable. I pulled the cable off to watch the caliper return just fine. Once I got the cable off it had a tight spot in it. Boot was torn in that side for a long while too. Surprised it lasted this long.
