I tried installing a 3rd light flasher/ strobe for my 2013 Jetta (w./ OEM LED lamp) without success
The module is called LSC-100A (ebay and Amazon is full of them)
http://www.ebay.com/itm/161805196247?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Issue is that it works fine if the engine is Off, but is no longer working when the engine is ON.
I thought is because of the higher voltage when charging, and tried reduce it with one or two diodes.
Still, when I start up the engine, the rig stops working...
have you had any similar experience?
Thank you
Thank you
