third Brake light Failing
paperthin
Toronto
15 A3 TDI
So on my 2015 A3 TDI the 3rd brake light does not come on. I took it off and bench tested it, it is fine. I am about to go out and double check that 12v is going to the connector but not sure if that is going to work. I will scan with VCDS shortly too. Is there fuse I can check? Any other ideas? Everything else is working properly.
paperthin
Toronto
15 A3 TDI
Scanned and got the following which is no surprise.
11274 - Bulb for Center Brake Light
B12C6 15 [009] - Open or Short to Plus
Other places on the internet suggest loose solder on the light. This is not the case as I benched tested it again, and works perfectly, all diodes on bright.
I cleared all faults and will drive on monday to see what comes back.
I am inclined to just let it go for now. Anyone have schematics?
paperthin
Toronto
15 A3 TDI
Well...i haven't figured out what is wrong. I tried to measure the voltage out of the cable connector but had difficulties. The fault comes on immediately. If I figure out anything else I will update. I was hoping it was a loose solder like many people on the internet suggest. The cheapest I can find the light right now is $150 CAD.
