Gothmolly
Tossed the cable a while back, but the car has lasted and lasted and lasted. Is it worth the risk buying a "genuine" cable off ebay? Or should I just buy the cable from Rosstech for $199?
This post is useless.Time or money.
Ross tech will be there in a day or 2. It will be 230 bucks. If something goes wrong ross tech is there.
You could order a knock off from Amazon for 20. It will be there just as fast. Getting the software to work might not happen. I gave several hours then pulled the trigger on ross tech.
Used ebay who know what happens if it doesn't work? Sure you'll get your money back then you can go buy a new one. When I was looking last year I think I was seeing 125 to 175. So 50 to 100 bucks saved but have to wait several days for auction to end.
Apparently he throws useless tools and comments awayso you threw away your old ross-tech cable???
Less in fact, since $200 no longer gets you unlimited VINs.if you bought a new one, it woudln't really have any more functionality for your mk4 anyway.
take 'emI bought a Kii VCDS on here for $100. Already had an old laptop to plug it into.
KII has unlimited vins and does logs on an ALH just fine.
I don't know what the logs mean but I can do logs, ha.
Sadly out of production. i mostly just need it to report on things, like injection per cylinder, boost vs. rpm etc. Is there a "lite" version maybe?I bought a Kii VCDS on here for $100. Already had an old laptop to plug it into.
