The Turtle
- Joined
- Jul 24, 2006
- Location
- rural Maryland
- TDI
- 1996 B4 Passat wagon, SpeedTuning chip, 360,000+ miles, 1996 B4V, 306,000 miles on original engine
I learned a bunch of stuff on the way to learning other things.
First, I learned that Car_54 is indeed a wizard, even if my 1996 B4V's leaky IP put him through hell. The car is now clean and tight, and thanks to a side-excursion into repairing the case pressure relief valve with extreme prejudice, it pulls clean and fast all the way through the power curve and feels much happier. And my girlfriend no longer complains about smelling like diesel.
Second, I learned again that as a TDI owner, I am a complete failure in that I do not have a spotless white repair lab staffed by guys in white coats who are prepared to pull the entire engine and driveline to address the most minor of maintenance or repair items.
Some of you might have read this thread from a couple of years ago when I had to replace the AC drive pulley on my other B4V:
http://forums.tdiclub.com/showthread.php?t=275570
Well, this time, I have a few more choice words about Volkswagen and its approach to ease-of-repair.
So, THANKS, VW! I really appreciate that to remove the alternator, I need to remove the serpentine belt tensioner pulley, and that removing the tensioner pulley is a lot easier when the alternator has already been removed!
I also appreciate it how on some cars, including mine, the upper alternator bolt can't be fully removed without also taking out THE FRICKIN' AIR FILTER BOX.
I also appreciate how you designed this car to be maintained by humans whose fingers are as thin as feeler gauges but with the grip strength of the Incredible Hulk.
I doubly appreciate those weird steel insets in the flanges on the alternator mounts that ensure that when you remove the alternator, you can't replace it because the insets provide about -0.2mm the clearance you need to re-mount the alternator. Fortunately, I have a huge frickin' bench vise and I pressed those suckers back out about two millimeters, otherwise I'd have laid into that thing with my ever-present 16lb sledge. Nobody was videotaping it, so I couldn't even have made money off YouTube ads with the mayhem.
And last, thanks for putting the right frame rail so close to all this that the back of my hand was required to do a good job cleaning off all the crud from said frame rail. I was really gonna wash that some day (and I mean it) but now all that crap is on the back of both of my hands.
Just wanted to say how much I appreciated that.
Turtle
PS: the car is now charging very well, and the wabbits and I will be headed to Wichita Thursday for national convention.
Turtle
