redline808
what is the thermostatic T in the fuel fiter. is there a 1 way valve in there? where can i buy a new one?
thanks.
thanks.
The purpose of the thermostatic tee is to control the return fuel flow at the filter. In cold weather the tee opens and sends the return fuel flow thru the fuel filter to warm fuel within the filter to help prevent gelling. In warm weather the tee closes and return fuel goes straight thru the tee and to the fuel tank.what is the thermostatic T in the fuel fiter. is there a 1 way valve in there? where can i buy a new one?
thanks.
You had fuel starvation then replaced tandem pump and lift pump? If the tee fixes it that was an expensive lesson.Has anyone ever seen a bad thermostatic TEE cause an airlock in a B5? I'm trying to find a cause for fuel starvation/hard starting in this car when the nose is parked uphill.
Lift and tandem pumps have been changed out to brand new. Thank you.
Living and learning.You had fuel starvation then replaced tandem pump and lift pump? If the tee fixes it that was an expensive lesson.
Funny you should ask that.He had fuel drain back to the tank. His fuel lines empty overnight, when he does not park nose down. This is on a PD engine with electric in tank lift pump and cam driven mid pressure fuel pump (tandem vacuum and fuel.)
Whizz, Have you had any issues with your clutch slipping? That can be a sign that fuel is leaking down into your flywheel area, from something up near your tandem pump.
Instead of spending $40 for the widget, I'd recommend switching to the Nicktane filter head that accepts the CAT 2-micron fuel filter. That will end all problems related to air entering the fuel filter via the thermostatic-T. And it will extend your fuel filter replacement interval to 60k or 80k miles or more. The 2-micron filters are much superior to the OE filters.
I had one of those, too, from Lubrication Specialist made by Greg Landuyt. It was an improvement over the OE filters, but it was awkward to swap the Cat filters, especially if you got the outside of the filter and the filter head wet with fuel. The shape of the Nicktane filter head is superior as it lets you get a really good grip on it. Not sure if I gave the old Lubrication Specialist head to someone else or if I still have it stashed away.I have one of the earlier incantations of this in my '03 (it was from someone else, and has a mounting point for the "T") and it's the shiz. The filter lasts darn near forever and it's the 2u common-rail rated CAT filter as well. I don't remember who made it; I may craft up a blocking plug for the T at some point (I do have a lathe and a piece of aluminum rod can easily be turned to take a couple of O-rings to seal the port) and be done with that.
I'm not sure if you remember that GTG in Milwaukee about 6 years ago. I got a new set of nozzles and Frank Irving calibrated them and installed them. Maybe you had already headed for home, but I could not get my Golf started. Jason, Frank, and I think Jeff from Rocketchip were all there, trying to help. Jason was ready to drive to his shop outside Madison to get another IP, because they all figured I wasn't getting fuel because the IP had failed.I think these are solutions in search of a problem. In 15 plus years of owning more than a few TDIs I've never had a problem with a fuel filter tee. I've replaced some proactively, and at $13 it's not a big deal. Use a good tee and a good quality fuel filter and you'll not have a problem.
I hope you are correct with this statement.I maintain the fueling systems on these cars are pretty reliable.
