Just swapped mine, what an undertaking!! Has anybody had one replaced by a shop? Or had one quoted? @oilhammer what do you guys book time on that?? And what’s a rough idea of your shop rate?
it was probably money well spent, it was a serious pain with a ton of parts to removeI recently had my thermostat replaced at the dealer. It was $1154.95, with just $104.95 in parts including new coolant.
well, hopefully mine is goodYep, the plastic pipe. 03L-121-065-T. They crack right where the double-lip o-ring slips into the thermostat housing.
You book 3 for that pipe? Seems like there is a boat load of stuff in the way to get that outIt is less of a pain when you are just replacing it. I've seen too many of those cracked and leaking, so I never do a thermostat without also replacing that. Curiously, the CKRA engine has that pipe made out of steel, but it is slightly different. Otherwise, that would be a nice easy upgrade.
That’s probably the smarter way to go about itNothing in the way once the front end is off:
I have the front end of some VAG product torn off almost always at any one given time, it seems. Getting ready to take the front off of another NMS Passat (a 2.5L gasser). Just had two CKRAs apart last week, another one still waiting for the OK out back.
Those were the simple days!!! I built classic cars for 15 years, everything was A ok until the 70s and then we had a nice little reboot of manufacturer and engineers actually using their brains again in the like late 80sYikes. The last t-stat I replaced was on my 4L Jeep XJ. Took all of 10 minutes and zero cussing involved.
I had my coolant outlet flange leaking. That was fun to track down.Thats true. Luckily I havent seen many coolant leaks from a CJAA engine.
That's an interesting concern here: dealer list for 03L121111AM is $131 (discounted to $87-ish + shipping by some online vendors); FCP Euro offers the OEM Mahle Behr 03L121111AC (original p/n) for $51 shipped, and idparts sells a no-name aftermarket for $30. For me, if this were a 30 minute job (including coolant drain/fill), I'd say go with the low-cost part. For a 3+ hour job, OTOH, is it worth trying to save a few dollars on a no-name aftermarket part of unknown quality...what is the recommended replacement thermostat?
OE or aftermarket?
@VCDS reading 180*, what was the dash reading? Did you use an o.e.m. replacement? All the info. I could dig up says o.e. thermostat @ 188*. Seems too low. Have you seen MPG difference with new t stat?Dash gauge is nearly useless to confirm if the T-stat is worn out or not. I just changed mine out @185k miles, would only get to 180 via ODB readings before, now it will get up to 200 at low load, 212 at sustained 85mph speeds through the mountains
