RabbitGTDJoe
More, only 10 pics to a post ...
The nozzles for now until Race 520's come into my budget...
thanks to Karl...
Marking and aligning the MKIV style adjustable inection pump pulley hub and setting initial timing marks for easy reference down the road...
Attempt to work with the timing belt backing plate so I could use the upper cover. It worked, modfied, fit, etc. However, once the hub was pressed to the pump and the pump pulley installed and tightened...the assembly rubbed...so scratched the upper timing belt cover and backing plate...
Current status of engine...almost ready, only a few things to do and install the exhaust manifold w/ turbo (retapped for larger studs) as well as the intake manifold once in the car.
The MKIV injection pump pulley will be so sweet. It adjusts very easily and will make "on the fly" timing advance/retard a snap with the dial indicator.
Thats all for now...
Joe
Joe
