So the hunt continues. To summarize the problem, the car is not producing enough vacuum; it's resulting in failed power brakes. This vacuum system is causing some headaches, and I would just like some clarification on a few items.
1. Is my method of checking the vacuum OK?:
Using the vacuum gauge, I tee'd it into the middle bulbous side nob on the brake booster hose.
On my working tdi: ~12 inHG. (I believe this should be > 24 working correctly, I need to replace the hoses on this one)
On the non-working tdi: ~2 inHG.
2. Is my method of checking the vacuum pump OK?:
When I disconnect the hose from the tee from the vacuum gauge, and plug both sides, I believe this will check the vacuum pump directly.
Working tdi: > 28 inHG
Non-Working tdi: ~2 inHG
3. The steps I have taken:
A. Today I replaced the power brake booster with a used one.
B. I replaced the vacuum pump with another used one a month ago.
C. I swapped in a used N75 to check if there was any difference, and there wasn't.
D. I swapped the entire vacuum system with the used one that came with the engine I replaced.
4. My next steps in order will be to:
A. Replace the vacuum hoses.
B. Swap in the old vacuum pump I replaced it with.
5. The assumptions I can make:
A. I know vacuum pumps rarely go out, but I suspect it because of the vacuum pump test I did.
B. The brake booster looked physically better than mine, but it still could be an issue.
The vacuum hoses should be replaced no doubt, but what do you guys think about after that if I still have problems?
