AndyBees
- Joined
- May 27, 2003
- Location
- Southeast Kentucky
- TDI
- Silver 2003 Jetta TDI, Silver 2000 Jetta TDI (sold), '84 Vanagon with '02 ALH engine
Guys, I've been dumping files, documents, etc., that I've saved over the years in Word, Excel & Word Pefect.
Anyway, I ran across a "copy & paste" about doing the MAF Twist (history doesn't show when I saved the file).
What does this do? Is it proven to do what it is supposed to do?
Below is what's in the Copy & Paste file I have.
[You can do “the maf twist” otherwise you need a tune to get rid of the CEL.
Basically you remove the two screws that hold the sensor to the body and twist the maf sensor one way or the other. You need VCDS to do this .
You select the channel that shows actual verses requested and while engine is running you simple twist the maf sensor till the numbers are close and that’s it.
I place a mark on housing and sensor in case it moved but never did ,
I never put back the screws as half the hole is now covered. That portion of intake is under vacuum so it will not pop out.
I did that for years before I got a tune, never had a cel again nor noticed any issues.
I doesn’t cost you anything, especially if you have Vcds or access to one.]
