PaulB
I've seen all manner of confusion about glow plug relays on the forum, so I'm starting a thread with pictures I hope to clear up some of it. I am posting pictures for a 97 Passat; I hope someone with a 96 Passat takes pictures and posts them here too.
First, please be aware that the Bentley manual does not tell you where these things are. Also there are TWO sections of wiring diagrams, one for the 96 Passat and one for the 97; please make sure you are in the right section when looking at this stuff. For the 97 Passat, see page 118 AKA "No 36/6".
OK, this first picture is an under-dash one; to orient yourself, at the bottom left of the picture is the handle to release the hood. The fuse/relay block has been lifted from its bracket (very easy) and is hanging down, on the right (there is no way to get to the 180 relay without lifting out the fuse/relay block). The knee crash-pad (or whatever that thing is called) has been removed. BTW it is very easy to take off; there are two screws by the door (under a small plastic cover) and one about where your right knee would be (also under a small cover). You then pull the pad out toward the left; this takes a bit of muscle because it is tightly fitted (or maybe there is some glue) connecting it to the passenger-side knee crash pad. Anyway, you can see the relay 180, way up under the dash, against the firewall, and to the left adjacent to the fender.
You should not need to remove the knee pad merely to replace the relay, but any work on its mounting block will require removal of the kneepad. The relay block does come off merely by pulling straight back. However in doing that I stressed the plastic clip on the block so my block won't stay up there any more, oh well!
The next picture shows the fuse/relay block hanging down. The clips rotate on the bracket and then the block just lifts out of the bracket, a very slick design.
In this picture I am holding up the bracket with my thumb on the jumper box. Some have said there is no designation on it but mine has some numbers taped on. In the correct part of the Bentley wiring diagrams you just see a wire which is this jumper. It is the main power coming through for the glow plugs, eventually going up to relay 180. In the 96, the glow plug relay is here, not up against the firewall like it shows a couple photos back.
In this photo I have pulled the glow plug relay 180 off the firewall. The clip on top of the block is now broken. You can feel this click when the relay operates. You have to take it off like this to do any wiring work, like I want to do to have manually-controlled glow plugs.
In the following picture, the tip of my finger is touching the coolant temp sensor plug. If you pull that off (not easy, there is little room to operate) the ECU thinks it is very cold and will operate the glow plugs a full 20 seconds. I don't know if a code is thrown, I haven't checked that yet.
This next picture shows the coolant glow plug relay that is for a completely different set of glowplugs that are there to confuse amateur mechanics. The fuse for that relay is on top under the plastic cover.
Here is one I'm not sure of. There is a big (either 50A or 80A) fuse between the glow plug relay 180, and the battery, but I'm not sure where it is. Is this it?
Anyway, I hope the pictures help. Anyone game for doing the 96 Passat? Post your intentions here first so 3 people don't end up doing it!
