aberson
This is an old thread, but I figured I'd toss a comment in anyway.conejo_a_cuatro said:Now let's think colder. Firstly, although I talked about a coolant loop originally, let's be honest. TDI's don't produce enough heat to keep the cabin warm, so the likely hood of sufficient heat to ungel the fuel line is pretty small, especially close to starting. Hence, my heated pickup idea. What to do about the fuel line? Not so sure on this one. I'm leaning towards electric heat for the whole system, the question is what kind of mods will the electrical system need to support all the heating. Bigger alternator? Second Battery? I don't know.
I think the whole coolant loop thing is a little shady. First of all, it's not that much heat (as mentioned). And 2nd of all, that's a lot of extra places to have a leak in your coolant system and have a serious problem, not to mention potentially leaking coolant into your SVO.
Electric solves all those problems, but then you have the question of load on the electrical system (as mentioned).
So, what has plenty of heat and don't need to worry about losing any of it? Your exhaust. Googling turns up one place mentionining this, but I don't know if it's really being done in practice. I believe exhaust temps exceed 300 degrees F, plenty of heat there.
Instead of running coolant through the SVO tank heat-exchanger, why not run exhaust gas? Create a little spur off your exhaust pipe, and put some sort of thermostat-controlled-valve on it it to automatically open the valve when the SVO tank is too cold. It would have to be a small spur that didn't have any effect on the pressure of the main exhaust line.
I suppose the same sort of thing could apply to keeping your filter and svo supply lines hot... little shunts of exhaust with thermostat valves. maybe this is more trouble to hook up in practice.
And yes, leaking exhaust into your passenger compartment is a risk (on a hatchback), but I think you'd smell it long before there was a problem.
