Digital Corpus
Wbo2?
His is an ALH style pump where the sprocket is rotated to adjust timing.I imagine that can happen if the lines aren't loosened when the timing is adjusted since those you have to rotate the pump, more-so if the timing had to be adjusted far in either direction..
That's right.. "Most" of the engine is like the AHU..His is an ALH style pump where the sprocket is rotated to adjust timing.
that's a very nice power curve and something i'm going to shoot for. it must drive great on the road, what is your MPG like with this?Calculated RPM and torque
234whp, 373ft-lbs
Wasn't even hitting target boost, should be able to make 400ft-lbs
Almost smoke free
AHH with stock 11mm IP
PD Lift pump
Rosten H-beam rods
ASZ 18.5:1 PD pistons
R520 nozzles set to 230/340 bar
Stage 2 Colt cam
Ported head
GTB2056VL on a ported 1.6 TD manifold with adapter plate
2.5" exhaust, 2 resonators
SBC Stage 2 endurance clutch
Upgraded head bolts and main bolts
EVOMS FMIC
Custom boost piping
Custom intake.
4bar map
That should be everything.
