TorquePower
I was given a ‘04 Passat wagon TDI that ran when parked with a little over 100k miles on it, for $1 (yes, I wrote a check so there was a paper trail for the bill of sale). He stopped driving it because he had 100k or so miles on it and was working about a chain tensioner breaking and ruining the engin. He insisted the only way to fix the problem permanently was to do a balance shaft delete and switch to a rotary/gear drive. He sounded like he knew a lot, but the more I’ve asked him the more I realize he doesn’t actually have answers which brings me here and hopefully this is the correct place.
1) Does it matter where you buy the delete kit from?
2) What is the difference or pros/cons of the ALH kit and the BRM kit? I know they are both using previous model oil pumps/tensioners to resolve the manufacturing issue, but does it matter which one is used? Which is easier?
3) I’m sure after sitting for over a year here alone the battery is dead and needs to be charged, is it ok to hook this up like any regular car to a trickle charger, or is there something special I should know ahead of time? I know some German autos are funny with this and require unlock codes to be plugged in after those events.
4) I was told the vag com would be a must after completing the work, if anyone know the name of the exact one needed or where I can pick one up that would be great.
If anyone has any other helpful tips on how to proceed and not ruin this thing.
