thecause17
I've been searching and can't seem to find any info on testing glow plugs for the CJAA engine.
I've been having a hard cold start problem when the car has sat for about 24 hours or so, and it will run rough for a few minutes after it starts. If the car has been ran within the last several hours it's fine seemingly because the engine is still moderately warm. I'm sort of suspecting there is a problem with the operation of the glow plugs, but do not have any codes being thrown. The glow plug light stays on for 1-2 seconds or so. The owner's manual states that once the car is warm the light won't come on at all when it's time to start it, but this isn't the case with mine. It still comes on for the same amount of time, so I'm not sure if it's working correctly at all.
Does anyone know how to test the operation of the glow plugs while in the car? I have VCDS and the only thing I can find in there is testing for glow plug light. I'd also like to see how long they're staying on, but the problem is since they only come on when you first turn the ignition on, I lose my connection with VCDS if I turn off the key to turn it back on again to operate the plugs.
