FluffySmooth
- Joined
- Dec 17, 2018
- Location
- Georgia, USA
- TDI
- 2003 Alaska Green Jetta ALH TDI sedan 180,000 miles 02J 5spd transmission (aftermarket injectors, unsure of brand)
Hello all! I have been with this site for a while now, but here is my first post. I have a 2003 5-speed TDI Jetta and I am having a terrible transmission leak problem. It has been leaking a small amount for half a year or so, and I could never find where it would leak from. I would usually add transmission fluid every oil change (every 5k miles). Usually not even half a quart at a time. I have been running Valvoline Synchromesh. About 2 months ago, I determined that I thought the driver's side axle flange seal was the culprit of my leak. So, I replaced it with a brand new one. That was not the issue apparently. Today I have determined that it seems to be coming off the top of the transmission and falling down the transmission. After that, of course, all over the undercarriage and out the back.
My initial hypothesis is that it may be the shifter linkage seal? Looking to see if anyone else has had this issue. If we suspect it to be the shifter linkage seal, where would I find one to purchase? The little searching I've done so far has not been successful.
Additionally, everyone on this site seems to have mixed feelings on their favorite transmission fluid from the OEM fluid to Redline and more. My Valvoline Synchromesh is quite thin. Is this Synchromesh "thinness" hurting me as well?
I have tried to provide pictures below as well. I am not sure how to share pictures within the post, so I have provided a link to a shared Google Drive folder. They were all taken today. It's been driven about 2k miles since I checked the transmission fluid level. I have watched closely, and only today has it been this bad of a leak. It is so bad it is peppered all over the back of my car. Thanks to all in advance for their assistance.
https://drive.google.com/drive/folders/1SEEDJ8i-NdO3MuRGdeZAcDx5tNg36_oL?usp=sharing
UPDATE: I cleaned it off top and bottom, drove it to work and back (about 20 miles either way) and it looks just as bad as before I pressure-washed it. Still coming off the top of the transmission somewhere. Still think it is the shift tower. IT IS NOT OVERFILLED
UPDATE 3/25: Cleaned it again and drove it just up the road and back. I definitely looks like it's leaking around the Axle seal now. Frustrating because I replaced the axle flange seal not 5k miles ago. I wonder if there is a larger problem with something besides the seal? I just ordered another seal from ID Parts and will have to put it in. Last time around I put RTV around it too so it would seal up better.
UPDATE 4/18: It has been a while since I worked on my car, but I thought I was post an update in case anyone else runs into this problem in the future. After I installed the new Axle flange and seal, I got the inner CV joint reattached and noticed the flange has some play in the transmission. The flange can be slightly "jiggled" in any direction. Everything was tightened down properly, but it still had some play to it. This means it is is most likely something like the bearing around the differential. This is the noise I am hearing, and it is most likely why my transmission leaks.
