temp warning light
Dieseljack
Washington
2004 GLS
I need some help, 2004 TDI Jetta, 5 speed manual. Yesterday my over temp light started blinking. I checked coolant level (same light?), and found it full. No other symptoms, temp gauge is, as usal, at a constant 190°. Any suggestions would be appreciated. Jack
CoyoteStarfish
Miami, FL
01 Beetle
If it is the same as the Beetle, flashing red is low coolant. As I recall an open circuit will cause this light to flash. You can pull the coolant level sensor plug on the reservoir and jump the pins with a wire/paperclip/etc. If the light goes out - bad sensor or connection corrosion. If the light stays on, bad connection or wiring. You can also use an ohm/continuity meter on the sensor itself to confirm the status of the float sensor.
In any case, a healthy dose of CRC contact cleaner and some dielectric grease can't hurt, even if turns out to be a bad sensor and will prevent any future corrosion issues.
Seatman
Scotland
2014 Skoda rapid elegance 1.6 cr tdi
A lot of guys over here just give the sensor a quick brush with an old toothbrush, seems to do the trick.
Genesis
Sevier County TN
'03 Jetta Wagon
The sensor probes get covered in gunk and then don't conduct. It starts happening only when cold and progresses to happening when the engine is cold, even in warm weather. Attempting to clean the probes may work for a while but it's almost impossible to get them completely clean. The reservoir is only about $20 and the biggest hassle in changing it is that to avoid a mess you need to partially drain the system (which means removing the belly pan to get to the valve on the radiator)
Dieseljack
Washington
2004 GLS
Thanks very much ! Will give that a try, ohm meter will be easy check, clean connections, can't hurt .. Will let you know the results.. Jack
