Greenbug76
I have a 01 Bug. I was given this car due to a bad alternator. I fixed that problem and started driving the car. The first the car over heated and the light turned red. I drove the car home and filled the fluids up. Took it back and it over heated again light was red. Came back added more fluid. Never over heated again. But light stayed blue. So I went for another spin and after about 20 minutes . Light was blue but started blinking. Pulled over check fluids and light stayed steady but blue. After a little while light started blinking again. I checked codes but forgot to write the numbers down but said temp sensor shorted to ground and something about locking something. Does the light change colors the car warms up and what could be the issue and if it is the temp sensor where is it at. Can car be driven until fixed?
