• Server migration complete
    In the early morning of September 26, 2020, our migration to new servers was completed.
    Things seem to be working as expected, but if you notice any issues including not receiving email notifications,
    please vistit this thread for more details
Temp gauge dead, but vagcom picks up coolant temp
erasedhammer
Maryland
1996 Passat
1996 Passat TDI.
Temperature gauge in gauge cluster always shows nothing, seems completely dead.
Hooked up my vagcom scanner and it can read the coolant temperature just fine.
Does this mean that the gauge is the problem and not the actual sensor?
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2003; 2016 A3 e-tron
I don't know about the Passat, but there are four pins on the Mk4 G/J/B cars. I don't know the pin-out, but I'd guess that one goes to the gauge, one to the computer, one for ground and one for...good luck(?).
Who knows. But I've seen something similar on one of my G/J/B cars, and sure enough, replacing the coolant temp sensor made everything work properly again.
Again - I may be way off base, but that's my $.02. Open to correction.
Mongler98
Northern MD (HAGERBUSH)
not uncommon for the cluster to have issues, i would not be surprised if the wiring harness behind the dash is damaged or that the PCB has started to delaminate the solder points. easy way to find out, pull the cluster out, its very easy to do, test the wires coming into it for the cluster and inspect the cluster and or test it, not sure what the volts and ohms range is supposed to be for the coolant gauge but im sure someone else can chime in.
I would just get a scangaugeII and put it some place easy to see without taking your eyes to far from the view ahead. the temp gauge was and is fairly uselss as it has a wide range that just shoes strait up normal temp reading. you can start to overheat the engine and the gauge will still say its ok. worthless POS vw garbage.
erasedhammer
Maryland
1996 Passat
Yeah I wouldn't mind it, only the coolant light is flashing at me. I figured they are connected problems... maybe just low coolant.
JETaah
mi 48836
96 B4V, 1999.5 jettaIV,2005 BEW Beetle
Could be that the reservoir's probes for the coolant level are coated with funk and giving a false reading if your coolant level appears to be right. On A4 cars they are exposed where you can run a brush across them to clean them. Don't think that they are accessible on the Passat's reservoir.
If that is the case then a replacement reservoir is not that expensive.
https://www.idparts.com/coolant-expansion-tank-a3b4-p-1157.html
But do a continuity check on the harness leads to the ECU or cluster...don't remember if they go straight to the cluster or not.
Do you have any signs of contamination (bathtub ring) in the reservoir?
erasedhammer
Maryland
1996 Passat
I think it's just dirty on the outside.
I'll check it today, but I don't recall seeing any fluid in there....
Engine still stays at temperature, IR temp monitoring, so I never bothered to check the coolant level
1996 Passat TDI.
The scan tool data comes from the Engine controller side of the CTS, not the gauge side. And on that car, the Instruments work a little differently than the newer cars.
The sensor for the older cars used to be 357-919-501-A but got superceded to 6U0-919-501-B some time in the last decade. I would try that first, cheap and easy.
AndyBees
Southeast Kentucky
Temp sensor is the problem .. follow Oilhammer's advice.
The same issue is going on with my 03 TDI Jetta, the gauge is on zero. I plan to change it when I do the TB job. I've seen this numerous times.
Mongler98
so why then does my 98 jetta have a 0 reading on the scangauge when i disconnected the temp sensor on the upper hose? i thought the b4 and the jetta both had nearly the same engine?
That is not the sensor we are discussing. That is for the A/C and A/C alone. Has zero to do with the Engine controller, or the gauge in the Instruments.
