Tell me about Toureg TDI's 2013+
hutchman
Virginia
2006 Jetta TDI 5 Spd. / 2002 Jetta GLS TDI / 2013 Jetta CR 2.0 DSG / 2012 Touareg Executive Series TDI
Second video shows an audi engine but it's the excat same, apart from engine cover.
Edit and big whoops. I quoted the video that talks about the CNRB, not the CATA.
This is video about CATA ... and thus about my comments on the HPFP:
More questions about the CATA video. He says that the HPFP that was in the original first gen was pretty much bullet proof (can we still use that pump? Probably not but had to ask) but the pump in 1.2 gen (shared with CNRB I believe) can blow up any time for a number of reasons. I just scored a 2012 with CATA with 114k miles and I'm wondering if I should, as part of preventative maintenance, go ahead and replace HPFP and injectors, since injector seals start to commonly leak around 120k etc.
Would this be a good idea? I was also thinking, if fuel dilution is happening due to bad injector/seal, that could contribute to rear main seal leaking and also timing chain issues (quality of oil degraded). Just "resetting" the fuel system could potentially have positive effects in other areas besides just preventing little metal bits from going everywhere.
Anything else I should change? Could a weak lift pump in tank contribute to HPFP failures???
I recently had to replace my MkV lift pump (has 260k miles) as it wouldn't start on a super cold morning but would a few days later when it warmed up. I changed the fuel filter while trying to get it started and I noticed that when I tried to run lift pump with VCDS, I could hear the pump run but never got fuel to come out of bleed screw hole. I had been noticing for quite a while when I did Italian tune up, I'd get a stutter around 4k RPM (felt like pump was losing prime or something). So I replaced the lift pump and the high RPM stutter on a hard pull is gone, so I bet my lift pump has been weak or not working at all and main pump has been doing most of the work. I'm guessing the HPFP on Touareg might be more sensitive to something like that, so wondering if I should just bite the bullet and replace lift pump too while I'm at it.
TurboABA
Kitchener, ON
RIP-2010 Jetta 6spd 2014 Touareg Execline
You're willing to put that kind of coin (I'm assuming you've priced out the parts already) into PM to replace working components on a ~12-14k vehicle? Is the rest of it mint or something and it doesn't require any actual maintenance or fixing?
Mozambiquer
Versailles Missouri
I feel like ODBEleven is alot more handy especially cause it can read off your phone. Unless you dont mind just keeping the laptop in your car the whole time.
I've used and have both and the only thing I like better about obdeleven is that it is highly portable.
I have a hex-net interface though and it checks both the boxes of portability and usefulness. It also doesn't require a data connection for the phone as it creates a wifi signal.
hutchman
Virginia
Well, I probably shouldn't have gotten it if I had better judgement (my kids, ahem, adult children, gave me a T shirt for Fathers day last year that says "In my defense, I was unsupervised", but my wife actually went along with this purchase!), but I couldn't help myself ... even with admonishment from some here ha, ha. Maybe this will finally cure me of my TDI disease!
I can get OEM reman injectors with a warranty and new HPFP for like $2k. And will do work myself (have a 2 post Bendpak lift in pole barn), so yeah, I've probably lost my mind, but it's within my pain threshold.
The vehicle is immaculate, looks new inside and out. Oh, I did find something else wrong with it ... the driver side door lock button doesn't work. And I didn't like it not having a dip stick so I ordered one for it.
I did a VCDS scan and I remember seeing something wrong with the electric cabin heater and a few other things. Man, VCDS auto scan took forever! I'm used to scanning Jetta's ha, ha. Man there's a lot of "stuff" there.
Saw a few other "intermittent" (I hate seeing those or the "implausible signal") things but none of them were critical from what I remember.
I plan to look at the injector quantity stats and timing chain info when I get a chance. Dude used correct oil and did 6k OCI so I felt ok about it. Time will tell. Like I said, maybe this thing will "fix me" ha, ha.
TurboABA
Kitchener, ON
Post scan... let's see how OK this thing is.
Do you plan on doing all the other missed "regular" and routine maintenance stuff as well?
TurboABA
Kitchener, ON
And if you don't want to share all that, just show me these two values... for my own entertainment
Code:
IDE00584   Distance driven since erasing DTC memory
IDE00603   Number of driving cycles since erasing DTC memory
hutchman
Virginia
... Do you plan on doing all the other missed "regular" and routine maintenance stuff as well?
Maybe, if I knew what they were. I'm new to the platform so go easy and don't give me a heart attack. I'm getting old.
hutchman
Virginia
Code:
Yeah, those would be entertaining. I'll have to search for those as I never looked at them before. VCDS is like the Bible ... inexhaustible in what it contains!
The guy didn't have VCDS, but I imagine his son does but he doesn't live near buy. I understand he's got a diesel Touareg, a diesel Cayenne and several gasser Cayenne's. He did the transmission service recently.
hutchman
Virginia
Post scan... let's see how OK this thing is. ...
You got it. (You asked for it, you got it ... Toyota). I don't think I saved the original scan so will have to go do it again.
I'm more interested in what sounds this support bearing thing makes when it's going out. I hear noises that I don't know if it's normal operational noises (just cause I'm unfamiliar with it) or if it's an issue. I know the service manager at VW dealership, I might have one of his guys that's familiar take it for a spin.
TurboABA
Kitchener, ON
Without seeing a scan, I don't know if you have a UDS or a CAN controller, so it's hard to tell you where to look.....
Typically, you go under engine and advanced measuring values and select the ones you want from the list
hutchman
Virginia
That sounds right. I've got HEX+CAN ross-tech cable that I got in like 2005/2006. I don't think it supports newer versions of VCDS or newer cars but it supports everything I currently have.
TurboABA
Kitchener, ON
Cool story, but you're yapping about your interface while I'm talking about your engine controller..... not really sure why anyone cares what cable you're using at this point since we're talking about how information is pulled from your specific controller.
hutchman
Virginia
Whoops. I just realized my post about the HPFP I was talking about quoted the video that's on the CNRB, not the CATA. I edited my post with the video that covers CATA which has the comment about the HPFP my post was talking about. Sorry about that! Sometimers!
hutchman
Virginia
Because I'm not familiar with the "newer" stuff and haven't kept up with it, so was just giving you full disclosure as to what I have in case that mattered cause I don't know that I've ever heard of UDS before. But I know what CAN bus is as I've developed products that use CAN bus. I know there is a limit to what I have will do and I never upgraded to whatever is current today.
TurboABA
Kitchener, ON
I'm using an RS232 cable... so don't worry... you're not the only one outdated or not modern.... get over it
hutchman
Virginia
Already beat you to it. Found some of this stuff yesterday ;):
Looks like it entered the VW world here in the US in 2008/2009. Only this year did I acquire/work on any VW vehicles that have ISO 14229 (UDS).
Yep, just yet another way for the pencilneck electronic engineers to further justify their job. And pile more costs on to the consumer.
hutchman
Virginia
Here are the faults so far:
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H17 0008
Revision: 56H17--- CVN: 66FD9600D45710C1D45710C1
Coding: 292A4012233600050000
Shop #: WSC 05901 444 00000
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 366951EA89504439AB-8062
VINID: 9E65D66C94A00135000011042421C73E97
1 Fault Found:
17277 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 0D860000000000000000
Shop #: WSC 31414 790 00001
VCID: 73EFA8FED2A211114C-8026
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000125928016
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 20
Reset counter: 40
Mileage: 180819 km
Time Indication: 0
Date: 2023.09.27
Time: 09:55:02
00956 - Key 2
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 182840 km
Time Indication: 0
Date: 2024.05.02
Time: 10:55:42
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: B686200A80
ASAM Dataset: EV_AirCondiFront 004001
ROD: EV_AirCondiFront_VW52.rod
VCID: 74EDABE2DFAC162955-8020
1 Fault Found:
0296 - Control Module for Auxiliary Heater
B10C0 31 [009] - No Signal
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 254
Reset counter: 120
Mileage: 173405 km
Date: 2022.10.26
Time: 10:03:24
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0152409887
Coding: 0186123A28B9509580A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 147111753
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P0 959 591 HW: 7P0 959 591
Component: J245 PS30.050 H07 0006
Serial number: WOO1249223/
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 A HW: 4H0 959 591
Component: J394 PS30.050 H07 0006
Serial number: WOO1251235-
Coding: 191100
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 40
Mileage: 180819 km
Time Indication: 0
Date: 2023.09.27
Time: 09:55:01
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 172100378
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
VCID: 7CFD83C2F7FC5E691D-8028
2 Faults Found:
0054 - Pinch Protection Strip 1
B11DB 11 [008] - Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 0.82 V
0057 - Pinch Protection Strip 2
B11DC 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
TurboABA
Kitchener, ON
Please code wrap when posting scans to make it easier to read, etc. Like this.
Code:
1 Fault Found:
Revision: 00002001
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 40
Mileage: 180819 km
Time Indication: 0
Date: 2023.09.27
Time: 09:55:02
00956 - Key 2
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 152
Mileage: 182840 km
Time Indication: 0
Date: 2024.05.02
Time: 10:55:42
Coding: B686200A80
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 120
Mileage: 173405 km
Date: 2022.10.26
Time: 10:03:24
Coding: 191100
Coding: 191100
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 20
Reset counter: 40
Mileage: 180819 km
Time Indication: 0
Date: 2023.09.27
Time: 09:55:01
Coding: 0533314003
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
TurboABA
Kitchener, ON
Might want to look into the age and stats of your battery there..... it appears it's been killed before!
You have a UDS engine controller, so extracting the information I mentioned in #36 above is just like I said... go to engine\advanced measuring values and select from list those two things.
TurboABA
Kitchener, ON
Should probably also start your own post since we've hijacked this dude's post pretty bad.
hutchman
Virginia
Code:
Entertained yet?
hutchman
Virginia
I have a new battery, just haven't put it in yet. The guy never replaced it the whole time he had it (2019 til now - 5yrs).
TurboABA
Kitchener, ON
Entertained yet?
You have no idea.... I'm jumping up and down with joy at the moment.
So that, coupled with the fact that you've cleared all your readiness monitors is a very good thing.
You can now go into the engine controller and blow away that singular intermittent code if you care to do so.
hutchman
Virginia
I haven't cleared a thing yet. Only scanned it.
hutchman
Virginia
What I said isn't something that you do..... the system does it when all is good.... you just didn't understand what I said.
Um, I think after 19yrs of messing with TDI's and VCDS (VAG-COM back in the beginning), I know how readiness works, but thank you for your willingness to educate. For anyone that doesn't now about "readiness" (those "Readiness: 0 0 0 0 0" lines in my scan above):
... and on some vehicles you can set readiness on some things, so I was simply responding to "your words":
.... So that, coupled with the fact that you've cleared all your readiness monitors ....
Words have meaning. Perhaps a better word choice would have been "since your vehicle has already passed all the readiness tests; a very good thing, you can now go into engine controller ..."
Oh I've understood you line of questioning all along ... that I'm probably an idiot and most likely got suckered with the purchase. I have a sarcastic sense of humor too so 'takes one to know one' :ROFLMAO:
Yeah, I need to go start another thread, crapped this one up. But it has mostly been relevant to 2013+ Touaregs cause the stuff I've mostly talked about (injectors and HPFP) are the same on both CATA and CNRB.
I thought me mentioning the "D" word (fuel "dilution" possibly contributing to the oil leaks mentioned in the videos) would probably kick off some spirited discussion ... but crickets.
TurboABA
Kitchener, ON
If you just want to argue about linguistics, I'm down.... but first, if
Words have meaning.
What dafuq does this mean? (if like you claim, you understood what I said)
:rolleyes:
Or maybe I'm an idiot who doesn't understand what #53 above means! (and as such, was possibly suggesting that you "cleared a code")
hutchman
Virginia
:rolleyes:
"cleared" was your word bro.
Meant exactly what I've said. I've only scanned it. I've not cleared any DTC's or attempted to reset any readiness codes ... further clarifying the "main point" ... all I've done is scan it. So I think we're done here.
