TDIclub Secret Society of BMW Owners (SSBMWO)
Steve Addy
Iowa
97 Mk3
After owning my 535d for 2 1/2 years, still under CPO warranty and only 75k miles, the dealer informed me that I need a new dpf. They rolled their eyes when I asked how much and wasn’t it covered by the warranty. Handed me a sheet that said it wasn’t. They estimated $6,000! Wouldn’t even give me a service report.
I am driving my old Jetta again and looking for a nice Passat.
The attitude of the service department has been “you should expect these kind of costs.”
Any efficiency benefit you might have achieved by driving the diesel was just eliminated by a $6000 dpf replacement price tag.
Sorry to hear of it.
Steve
TDIMeister
Canada
Get a second opinion from another dealer, or take it up to the corporate level. The emission control system is warranted for 8 years/ 80k miles by EPA federal mandate.
State motor vehicle emissions warranty provisions are in addition to, and do not void or eliminate, the federal emissions warranties under §207 of the Act. A vehicle that is within the federal warranty period and subject to regulations issued under §202 is therefore covered by the federal emission warranties, notwithstanding valid adoption by a state of separate warranties. Under this situation, the Federal and California warranty provisions are concurrent, and all vehicles, even those sold in California, are subject to Federal warranty provisions. Therefore the Federal 8 year or 80,000 mile warranty period for the specified major emission control components applies to all vehicles, including those sold in California.
n1das
Nashua, NH, USA
Twinkieflyer,
How does the dealer KNOW the DPF needs to be replaced? How did they determine that? What BMW specific codes are stored?
75k miles is way too early to need a DPF replacement. I'm only at 160k miles on my 2014 535dx (July 2013 build) with no DPF issues. My 2012 X5 35d is only at 270k miles and still has the original DPF. DPFs typically don't "go bad" unless they crack and DPFs in diesel BMWs haven't been known to crack. The DPF eventually gets loaded up with ash left over from DPF regenerations and the ash needs to be cleaned out or the DPF replaced. In big trucks, the DPF gets cleaned and reused. In diesel cars, they simply get replaced.
BMW-specific code 452A gets stored when the DPF is approaching its calculated end of life. 452A is an information only code for BMW service to inform the customer that they should schedule a service appointment soon for a $6k DPF replacement. Note that code 452A DOES NOT necessarily mean the DPF needs to be replaced yet. 452A does not trigger a check engine light (CEL) or limp mode and will not cause the car to fail an OBD-II scan for an emission scan to pass state inspection. It is nothing more than an information only code for BMW service. The DPF has a calculated life of around 200k km and 452A code gets set some time before the calculated life reaches 0 km. The remaining DPF life is calculated from a number of parameters so there is no set odometer reading when 452A gets triggered.
When the calculated remaining life of the DPF eventually reaches 0 km, code 4D4A is set. 4D4A is another information only code for BMW service which means the calculated remaining life of the DPF has reached 0 km and the car continued to be driven. 4D4A triggers a one time on-screen warning about the DPF and a DPF symbol on the instrument cluster and gets triggered at exactly 10 minutes after startup. The on-screen warning needs to be manually cleared and the yellow DPF symbol on the cluster goes away after about 20 seconds. 4D4A also does not trigger a CEL or limp mode and will not cause the car to fail an OBD-II scan for emissions testing. The car basically starts nagging the owner about the DPF after the calculated remaining life reaches 0 km. Note that code 4D4A also does not necessarily mean the DPF needs to be replaced yet.
In my 2012 X5 35d, I have codes 452A and 4D4A stored. The codes are permanently stored until the ECU (DDE in BMW-speak) is told that the DPF was replaced. 452A was triggered around 155k miles. 4D4A was triggered around 171k miles. The car currently is at 270k miles and still has the original DPF. I have driven 99k miles since 4D4A code was set. I get the one time warning and DPF symbol display at exactly 10 minutes after startup. I simply clear the on screen warning and drive on. The DPF symbol display goes out about 20 seconds later. I regularly check that DPF regenerations are occurring like they should using a Carly Bluetooth OBD-II adapter for BMWs. The Carly smartphone app is specific to BMWs. At 270k miles, power and fuel economy are still where they should be and DPF regens are still occurring normally so I know I don't have to do anything about the DPF yet. Exactly how far I can go with the original DPF is still a big "?".
You should find out how the dealer determined the DPF needs to be replaced and what codes were stored and please post the codes here.
Good luck.
n1das
Nashua, NH, USA
The fact that they wouldn't give you a service report is disturbing. Take it to another dealer, one that is competent for an accurate diagnosis and will give a service report. Please post what codes are stored.
It could be that something as simple as a failing thermostat causing the engine to run under-temperature all the time is causing DPF regenerations to be inhibited and then problems snowball from there. It is important that the engine run at the correct temperature at all times. Running under-temperature all the time will also lead to premature glowplug failures due to continuous "afterglow" operation trying to help warm the engine up.
If regens are inhibited long enough, codes 480A (DPF blocked) and 481A (DPF heavily blocked) are set and they will trigger a CEL. Regens are locked out if either of these codes are present. The dealer may have seen one of these codes and assumed the DPF needs to be replaced. The cause of the non-regens needs to be corrected first, otherwise a replacement DPF will soon get plugged up. The DPF likely does not need to be replaced.
You need to get the car to someone who really KNOWS these cars.
Twinkieflyer
Blacksburg, Virginia
2002 ALH 5spd
Thank you for the replies. N1das, your knowledge clearly exceeds the dealers. Roanoke is an hour for me and the next closest is Lynchburg which is 2 hours. This makes it difficult to shop dealers. I didn’t realize the federal law. The dealer doesn’t seem to want to talk with me at all now. He took my email address and said someone would reply.
He also said that was why they didn’t sell diesels, or take them on trade...
I am trying to be reasonable with them but they are not giving me much to work with. My wife is being treated at Duke right now so major distractions with that so hard to take off so many days from work.
I asked them again for a service report. CPO warranty expires tomorrow.
Steve Addy
Iowa
97 Mk3
Despite the expiration of the CPO warranty you have evidence that you brought a warranty issue to them before expiration and they refused to deal with it, or better said they attempted to make what should have been a warranty issue your responsibility when legally it isn't. I would press again on this and want legitimate service repot declaring the DPF bad.
The comment about not selling or taking diesels on trade, I have to believe that BMW might have an issue with this attitude and it just needs to be brought to their attention. This doesn't sound like something the manufacturer would appreciate.
Good luck with your issues, I'd say you might need legal help with this but I'm sure you already know this.
Steve
Twinkieflyer
2002 ALH 5spd
I want to thank everyone who has helped with advice on this problem. Without your advice I probably would have just traded the vehicle off.
Two days ago a phoned the BMW complaint line and related my story. Several times I was on hold for quite awhile. At first they said it wasn’t a warranty issue. Armed with the EPA letter info from TDImeister, I started down a different course, and was put on hold again. At the end they reluctantly agreed that the DPF was probably an emissions component, although they had been only covering catalytic converters. They told me to contact the dealer again. The dealer had already stated that the DPF wasn’t covered by the CPO warranty or the emissions warranty.
Knowing that the entire purpose for the DPF was emissions, I called a corporate attorney friend of mine who is vey technical and discussed the situation with him. Although he doesn’t do this can of legal work anymore, he had a former partner who does, and indicated he would be interested to talk with me.
Before I got to talk with him, out of the blue the dealership called me yesterday, to inform me that they had determined that they would cover the part via an emissions warranty claim and asked me not to drive the car. They even offered a loaner. I suspect someone had talked to them because this was a total about face. They reiterated again that 40%of their warranty work was on diesels and they made up less than 10% of their service.
They told me they had ordered the converter from Germany, it would arrive in 3 weeks and not to drive the car.
I have some doubts as to whether this is really the problem based on the info I have gotten here, but I decided not to question them. They said the new DPF is on the way and BMW was going to pay the $6000 warranty bill and they like big ticket jobs so be it.
I think I should look around for a real diesel shop if I don’t have time to do the work myself.
It is unfortunate that although our 5 diesel vehicles have been incredibly reliable, it has been very difficult to get reliable and knowledgeable service locally.
Since I got the new clutch in the Jetta last year from a company who is on this thread, it has been a real pleasure to drive, so I won’t really miss the BMW for a month.
Thank you all again. Oh, one thing I did come to find out, the dealer indicated they had been charging others for this problem. I wonder if they get a phone call....
TDIMeister
Canada
Glad to read that this appears to be on the way toward a positive resolution. Make sure everything else in the car is working in tip-top shape because one emission or fuel system fault is usually symptomatic of another imminent or developing problem. My friend has an X5 with similar issues, but unfortunately, he bought his with high mileage and won't be able to cite the EPA warranty mandate. Here's a snippet of our correspondence:
Damnit. So the DPF is giving a reduced efficiency warning. Do you think the cleaning products actually work? It sounds like some contain some type of catalyst to somehow oxidize carbon buildup. Of course it's impossible to know which ones are real or not. Some go into the tank, and others are put into the DPF directly.
Now it's giving a P0172 code for running too rich, and P2002 for DPF not running as efficiently as expected, and the SCR passive tank pump isn't working at all and is giving a code for that. But the first two things combined with the fuel dilution means I probably have a leaky injector that's spraying all the time. Man this is not something I want to deal with right now...
Do you think my theory that it could be a leaky injector? I would think that if it's spraying continuously, it could cause all three of the apparent problems. Slight oil dilution, DPF working less efficiently than expected, and running rich? Or would a leaky injector simply make the DPF hotter all the time, and not plug it? It would be like being partly on a regen cycle all the time. Or it could be making soot instead of burning, depending on how it's spraying? e.g. dripping vs. spraying a fine mist. This leaky injector theory could also explain why the economy readout is 5-6% optimistic. I assumed it was because the orifices are worn bigger than new, from the high pressure spray for many miles.
Unfortunately, I didn't realize this uses a new communication protocol and my old cables wouldn't work anyways. It's called ENET and most adapters are interfaced with ethernet.
It sucks because it's otherwise a ridiculously cool vehicle. Despite the miles, cosmetically, it looks newer than a 1 year old Toyota that had gone through one winter. I'm just afraid that the SCR system might need repaired, the DPF might need replaced entirely, and there could be a bad injector. The DPF is $2200 just for the part, and the injectors are $400 a piece (which isn't a huge huge problem of course...).
About 133k now. It seems like a common failure on most diesel cars of this age.
The key to a long troublefree car is to fix anything everything as soon as it crops up and not keep driving on with any issues. When this pattern gets more frequent and expensive than to your liking, seriously consider cutting your losses before it starts to really hurt the wallet and the resaleability gets even worse.
See, not all mandates are bad, are they? :)
Twinkieflyer
2002 ALH 5spd
I am trying to decide if I should dump this car after it is fixed or keep it, buy an obd2 of some sort ( I hear Carly is good) and find a good independent shop and a tuner.
The biggest problem I see is the service at the dealership. If I could get parts elsewhere it wouldn’t be so bad long term.
slo_dsl
Rochester Indiana USA
11 335d, 06 Jetta TDI (swap donor), 01 Golf TDI manual swapped w/ TD04
Might as well butt into this thread. Got into TDIs several years ago and a little over a year ago I picked up this turd. '11 335d. It's currently partially back together and once a few more pieces arrive it should have a bit more power and hopefully much better mpg.
D-Cell_Mekanick
Sandwich, IL
2015 Honda Civic SE
I’m going to bring this post back from the dead. I’ve had a couple VW TDI’s throughout the years, been out of them for about 6 years now. I’ve been seriously considering another with diesel gate behind us now. I’m also exploring the BMW diesel cars. I really like the xdrive options available. I’ve found a clean 328D xdrive and I’m seriously considering purchasing it.
This thread will take me a week to read through, a week that I don’t have before the car is sold. So if you could, please let me know the pros and cons of the bmw 328d. Also, if you know of a forum specializing in the bmw’s like this forum specializing in TDI’s, please let me know.
Jason
danix
Raleigh, NC
None now. Former: 2011 335d, 2010 Jetta TDI, 2003 Jetta TDI Wagon. 99.5 Jetta TDI, 98 NB TDI, 3 different black 96 Passat TDI wagons.
Jason
Not an expert on the 328d but I believe they are very solid and likely more reliable than the 335d/535d. Not aware of a diesel BMW forum but there is a facebook group that is pretty helpful - https://www.facebook.com/groups/1887738328130700.
tomo366
TDI Lifer, Member #68
Kensington, Maryland USA
2015 Jetta SEL TDI
My 2014 328D XDrive was a CPO car I bought it in 2017 with 32K miles on it it only has 64k miles now but Covid has killed my driving time the Car has been pretty much trouble free and anything has been covered Great Car! I still have my 2015 Jetta TDI SEL a wonderful car and I also have a 2015 Jeep Grand Cherokee OverlandvEco Diesel! love my Diesels
D-Cell_Mekanick
Sandwich, IL
2015 Honda Civic SE
Awesome news! I saw you on one of the forums I was searching, but since lost the web page. What forums are useful for these vehicles? Thanks!
jstn
norton, ma
gone to the dark side :)
My girlfriend has a 2016 x3d, which has the same N47 engine. The main issue is the CP4 pump, which there is a recall out for, however I don't believe parts are available yet. I flashed the x3 with a custom DUDMD tune, which has seriously woken the vehicle up.
tomo366
2015 Jetta SEL TDI
The BMW folks are a different breed…..they don’t for the most part do there own work and they don’t post much….and they tend to look down on the “D” guys……Bimmerpost is one of the forums I visit and Bimmerfest is another
jstn
norton, ma
really? pretty sure i did all my own deletes, FMIC upgrade, valve cover gasket, brakes, harmonic balancer, among other maintenance/upgrades. upgraded M5 brakes going on next weekend, too.
check out the facebook group "North American BMW Diesel Owners Group" there are P L E N T Y of "BMW folks" doing their own work... ;)
jstn
norton, ma
or are you referring to non-Diesel owners? i wasn't sure, sounded like a shot at all BMW owners... :)
tomo366
2015 Jetta SEL TDI
Not the Diesel guys but there aren’t many of us…..and I belong to the facebook group you are referring too….the 335D guys are fierce competitors and their cars are amazing….I do not believe in Deletes and like my stock car just fine
capt_slow
SoCal
2015 GSW TDI SEL
Some advice I posted on the Bimmerpost forums:
The 328d has had it's fair share of gremlins, but fortunately most are covered by either recall or extended warranty (EGR cooler, HPFP, transfer case, injectors). The 8HP ZF transmission is also largely bulletproof. The N47 diesel engine is a really old design that ended production here in the US in 2018. It's infamous for timing chain issues in the early days, but much less so with the TU design. Other gremlins on the 328d F31 include EGR cooler failures, Bosch CP4 HPFP failures, and transfer case issues. All of them have been disposition via extended warranty or recall. For this platform, I'd like to think BMW ironed out all the issues by LCI (2016+). But I also got a horse in this race, so take what I saw with a grain of salt. Find a car with these qualities:
  • Under 60K: this will give you an opportunity to change out the diff, tranny, and xDrive transfer case fluids. Above 60-100K its not recommended to touch those fluids at all.
  • Average miles driven of 10-15K/year: This value implies car was driven on lengthy distances that are healthy to the engine over the long-term. Seeing a car that does 5K/year implies short city driving, which isnt a good thing for diesels.
  • M-Sport: Really desirable option
  • Navigation: Really desirable option. You might not need nav, but the NBTevo headunit that comes with it is a really beefy unit and the UI is still really usable. The built-in 4G modem wont run into sunset issues like the 3G ones are going through now. I recommend getting it with the car instead of retrofitting it in.
  • SensaTec interior: I prefer SensaTec over leather for longevity reasons. Leather can last a while if taken care of properly, but in a used car you never know. Personal preference.
  • Maintenance records: There are not a lot of maintenance items prior to 60K. Check for oil changes and brake fluid changes. If there is any sign that the last oil change was done by a JiffyLube or non-BMW specialized shop, get the oil changed and make sure to use LL-04 spec oil
If you're eyeing a specific car, take the VIN to a BMW dealer and have them check the warranty status. Some of the extended warranty items for the injectors and HPFP are VIN-specific.
I think this needs to be clarified. Most BMW owners tend to not work on their cars and just leave it to the dealers. This is because most BMW owners lease their cars and all maintenance items are included for the first 3 years. Also, most drive their cars like (nice looking) appliances. The folks you find on Bimmerpost and Bimmerfest are BMW enthusiasts similar to VW enthusiasts you'd find here or Vortex. You'll find a wide demographic of people ranging from the newbies asking how to pair their phone to veterans talking spring rates for their suspension mods. Within the US BMW community, there does appear to be a echelon based on the rarity of the car. Diesels are rare in the US, so they are decently well regarded.
Some BMW owners do work on their own cars for sure. We sell parts to them ;) But as an owner I can vouch that the complexity of the vehicles make them more daunting to take on then an older VW. Compared to a newer, emissions controlled VW? Pretty similar in my opinion.
I very nearly pulled the trigger on a new '18 328d at the end of '18. Dealer was offering $12K off MSRP. I ended up not wanting to live through the depreciation and kept my 335d. Glad I did, as for many reasons I prefer that car. But it does scare me a bit when I think about what can break.
dogdots
Kansas City
None
Totally forgot about this thread...This was me passing a semi on a 2 lane road a couple of months ago in rural Kansas. BTW my 335d is not stock 😉
This is the first time I have posted on the new platform here, I took a new position in my company that is international and 90% travel 3 years ago so I mostly only drive from the house to the airport and back.
That was a fast moving semi! These cars are crazy fast. They start to really pull at about 90 MPH.
Love the "MPG" indicator pegged on zero... 😂
That indicator is both useless and irritating. You can switch the gauge to read coolant temp, which of course would be better, but the numbers would have no relevance.
dogdots
Kansas City
None
Peter - I was in South Boston and Braintree last week driving a Mustang 5.0 (thank you National 😃). I should have dropped by. I'll shout at ya next time I'm near.
1854 - That is definitely a useless gauge.
