TDIClub Forums Not Secure?
dowster
Platteville, Wisconsin
2002 Jetta ALH 5spd
The site is essentially using an old version of HTTPS which I guess is insecure. Depending on the hosting it shouldn't be too hard to upgrade it. I'd be willing to help out if needed.
VW Derf
Administrator
Richmond, BC, Canada
2010 Blue Graphite Pearl Golf Variant
Hi,
Yes this is due to some the server allowing old https connections. I'm hoping to have a test site up for some testing this Thursday to be tested before we migrate to a new platform, server etc. That should deal with this issue and many others.
Fred
romad
Palermo, State of Jefferson/Prescott, AZ
2005 Jetta GLS Wagon "Cranberry"
Thanks, Fred. I wasn't sure if it was correct or a "false negative" from Brave. I only started using Brave last month so I'm having to learn its notification system. This isn't the only site on which I'm seeing this.
romad
Fred, Brave is still saying the site is "Not Secure" up in the Address Bar. Wasn't this new platform supposed to fix that?
Update: The above was using a regular browser window.
I then opened a "New Private Window with Tor" and logged into the site from it where I am now doing this update. In this Tor-enabled private window, I'm still seeing the "Not Secure" in the Address Bar.
VW Derf
Administrator
The site is secure, the issue is the image showing it is insecure is pointing to a site that doesn't use https and thus the browser is warning you that something is insecure on the page. If you go to the main page you won't see that. That indicator just confirms that if ALL of the traffic to that page is transmitted via a secure method. Previously we used an older protocol as well and that caused issues.
If you were using doing something like banking I would be concerned about that, but on pages with images it is OK.
