Been making progress at a slow and steady pace.
New yokes are installed. These are high clearance units from JB Conversions, good quality product.
Only problem is that the flange nut doesn't fit the counterbore in the yoke, so I had to turn it down on the lathe by about 1/16".
Center crossmember is 2.5" square tube, 1/4" wall.
Not going to be quite the flat belly I hoped, but the bump for the t-case front output is less than 1.5", so I'll deal.
The transmission pan is still flush with the bottom of the frame rails.
The left front mount sits on a removable crossmember that goes under the engine.
Clearing the front shaft was a bit of a challenge. Crossmember is built up from 1/8" plate with reinforcements.
Working out where everything needed to be took some iterations and is the main reason I haven't had much to show in the past 3 months.
Also, rooney77 was right about the clearances, it was too tight.
Full articulation was less than 1/4" to the upper control arm - no bueno.
Turns out the TJ rear axle pinion is offset 2" to the right, so when I shifted everything 1" right, life just got better.
(at least until I try to fit the body back on)
Rear mount uses two rubber bushings, here's the mount that bolts onto the Novak adapter
Here you can just see it peeking out from under the tcase.
Next up:
1. Make the tabs to attach the rear mount to the crossmember
2. Pull the motor out of the way
3. Finish welding in all the tack-welded parts
4. Drill frame & install tubes for crossmember mounts
About a days work, right? Yeah, I should have it done by fall.
