N2TOH
you might want to try contacting these folks to see where you can get an oil free turbo.
http://www.miti.cc/new_products.html
The flexplate spacer fit up well, at least on the diameters. I think there's too little clearance around the heads, so I'm getting some different fasteners. But overall, I was pleased to see everything fit together snugly with a good pilot.
And for the first time ever, I present to you a AHF/4L65/NP241OR drivetrain.
Too shiny. Need to get it dirty.
Plenty of clearance around the back of the head, though I may rearrange the heater outlet once I see how much space the jeep firewall offers.
Ran into a problem with the starter fit with the oil drain - it doesn't. The starter will clear the turbo support bracket, but the braid of the drain line gets pushed right onto the positive terminal.
Thinking about getting the oil drain line with the flared fitting instead of the banjo. Does anyone know if this will work on this AHF motor?:
http://www.idparts.com/catalog/product_info.php?products_id=779&osCsid=7s33h02t45vo4a92a0eeqhg121
