TDIwestfalia
Would it be possible for a MKIII jetta TDI that is heavily modded to keep up with or beat a stock MKIII jetta VR6? A friend and I are having a little debate and I'm curious. Thanks
Would a Clydesdale be able to keep up with an Arabian? Can a Husky keep up with a Greyhound?Ginster17 said:Would it be possible for a MKIII jetta TDI that is heavily modded to keep up with or beat a stock MKIII jetta VR6? A friend and I are having a little debate and I'm curious. Thanks
Here's mine compared to an old stock 12V dyno I found on VWVortex years ago:Lug_Nut said:Torque is fine, until it runs out. Simply overlay the two engine's HP and torque curves and you'll see that even a huge number at some narrow rpm range is not a match for a lower number over a much wider range. It's the area under the curve that will indicate the better at this specific challenge. I'd always bet on the stock VR6 over the TDI (well, maybe not the V10).
So that's why the Budweiser wagon isn't pulled by Arabians...oilhammer said:Even with a trailer in tow, the mighty TDI's torque and turbo-supplied atmosphere give it an extreme advantage and downshifting is not necessary.
I think if you drove a VR6 in second gear up a mountain pass you would either need a new engine by the other side or you'd have simply run out of gas!Lug_Nut said:So that's why the Budweiser wagon isn't pulled by Arabians...
And the VR6 could be left in second so no downshifting is necessary there either.
Cripes! It's starting to sound like I actually like those lumps!
