Hi bernie, here is how I do it...I am so sorry to bother but I cannot get the black stone
Lab report to post as an image like everyone else has.
I've tried everything (including search).
Would any one mind giving me the dummy version
So I can post my results like everyone else - my report is
Pretty bad, I am looking forward to your expertise guys.
Thank you !!!!
Looking at this post I tell you his cSt is very low for LL01 oil it should be above 13 but he got 9.86 after 10000 miles so there is no protection for this engines where clearances were designed for cSt above 13.
Here is my used oil analysis of factory fill from my 2010 Jetta TDI. I hope this helps or maybe gives a confirmation to someone to compare with.
That what I thought so. Also HTHS should above 3.5 since this LL oils. So I read in this article (http://books.google.com/books?id=XjTaOqE...ity&f=false) that higher HTHS number oil have tendency to lose faster this HTHS. So unfortunately I had never seen those oil reports that is providing HTHS number.'Fly,
This is a new engine so it's natural to see more fuel dilution until the piston rings finish seating. He may also be using a biodiesel blend which can lead to fuel dilution under certain operating conditions. The 2% fuel is why this sample has thinned out, but it's still "in grade". I think this fuel dilution will drop with more miles on this engine.
The wear pattern and amount of debris is perfectly normal for the factory fill oil. The thought is that the potassium ("K"), is welding flux from a component on the engine. You'll find that the trace of potassium dissipates over time, but it can take 50,000 miles for it to completely go away.
I've seen very few (< 5%), newer TDI's where I'd recommend a service interval shorter than 10,000 miles, based on oil analysis results. This isn't one of them....
TS
